Knocking from Front
bronkone7
Currently Drives:: 2004 Renault Megane 1600cc
Knocking from Front
Postby bronkone7 » Thu Sep 23, 2010 2:30 pm
Have checked out forum & seen many answers to knocking from front of motor (not sure what side),but judging by these answers this would be m.o.t failure,yet i've put up with this knocking for 2 years now & the car has passed 2 m.o.t's.Does anyone know of a knocking where it wouldn't be an m.o.t failure ? :idea:
markren2004
Re: Knocking from Front
Postby markren2004 » Thu Sep 23, 2010 6:34 pm
top strut mounts or failing engine mount, under what circumstances does it knock ? turning, accelleration, braking ?
bronkone7
Postby bronkone7 » Thu Sep 23, 2010 9:05 pm
Just normal driving,going over sleeping policeman etc.Only notices when going slow 30 mph.
Cheers Brian
david_ihamer
Currently Drives:: Megane II Dynamique 1.9TD
Postby david_ihamer » Sat Sep 25, 2010 1:48 pm
if you have knocking and it's noticeable then something's no right. Could be lots of things.worn ball joints, bushes on shock absorbers, bushes and anti roll or even a broken coil spring....
Jack up one front side at a time, with wheels on full lock that gives you best view of rear of hub. With the wheel just off the ground use a spade to lever the wheel in various directions, only a cm or so no more, you don't want to drop he car off the jack. Check for movement on ball joints and shock bushes. You may need to have a second set of eyes or hands as one person will have to lever whilst the other watches.
The springs are harder to check. But my wife's dynamic had a broken spring at 40K miles..
Hope that helps.
If you're unsure have a mechanic check it out. If you've noticed it then you know somethings not right...
Sadret89
Postby Sadret89 » Mon Sep 27, 2010 10:38 pm
When I first got my car, it was only doing this sound when the car was at a stand still and I would turn my steering wheel to come out of a parking space.
Also make a bit of noise when the road is uneven.
Tonight driving, it started doing a repeated knocking noise when steering towards left only, could this be the steering rack?
mave17ick
Currently Drives:: Megane 2 1.9 DCI 120 2005
Postby mave17ick » Tue Sep 28, 2010 9:51 pm
I had this issue mine was loose bolts on the universal joint for the steering rack re-placed and re torqued cured the problem also the ball joints are quite common to fail on renaults
Sadret89
Postby Sadret89 » Sun Oct 03, 2010 8:57 am
Yeah I've got the same problem, tighten the bolts and replaced the wish bone, did the job for about a 2 miles till it started again, now it need a cv joint which comes complete with the drive shaft. more money :-(
bronkone7
Postby bronkone7 » Sun Oct 03, 2010 11:31 am
Cheers guys,
Going in garage this week to hopefully sort it.
Mechanic has idea what it is,but let you know.
Thanks for all replies
Brian
Sadret89
Postby Sadret89 » Fri Oct 08, 2010 12:11 pm
If its the drive-shaft or cv joint, try Driveshafts Ltd on eBay, the manufacture new drive-shafts and cv joints for most cars inc megane. and they charge a quarter of the price of a new one from Renault
bronkone7
Postby bronkone7 » Tue Oct 12, 2010 6:19 pm
Hi all
Car been in local garage today and there saying its most probably anti-roll bar drop link rod.
Its the only thing they could find a bit of play on,so as there not that expensive will renew them first.
Brian
bronkone7
Postby bronkone7 » Mon Oct 18, 2010 3:18 pm
Job done...hopefully.
Knocking appears to have stopped.
Inexpensive & easy enough to do.
Thanks for all interest.
Brian
Users browsing this forum: Bing [Bot] and 68 guests
