My gone wrong list, help
bangbang
Postby bangbang » Wed Sep 22, 2010 1:10 pm
anyone have some solutions to these?
1) Windows dont shut when cars locked (should they on an 53 priv?)
2) Buttons on doors have stopped working, tried WD40, and they work again for a day, and then break again, is there another solution or can they be cleaned?
3) Car starts now with no need to put foot on break or clutch? help
4) Electric cable for clutch has broke, and when i re-solder the wire, i get an electronic fault message and service light.
Have sorted out multiple other issues with this car already, and only had it 4 or 5 months, is cost close to a grand already with 101 issues. these are trivial, but thought for the cash, i may as well get a perfect megane for a time now before the next bit goes wrong.
thanks
tomalamix
Re: My gone wrong list, help
Postby tomalamix » Wed Sep 22, 2010 4:31 pm
Hello there!
I will answer after your questions, the items i may help:
bangbang wrote:Hi,
Try click twice on the lock button, it should close all windows.
Never had this issue, maybe someone else can help...
Maybe you have a brake pedal sensor wrecked. Did you check with your car turned on if the stop lights in the rear are on? Or it can have anything to do with your question no.4
Did you solder the wire correctly? It shoulnt have any error if everything is ok...
thanks
Users browsing this forum: Google Adsense [Bot] and 25 guests
