First I went and bought some Ford Focus RS green
then I had them sprayed gloss black with the green lip, now they look like:
and on the car they look like:
needs dropping like it's hot now
Anthony wrote:What are those? 17's?
You did it the wrong way roundYou should lower, then put wheels on. It stops you looking daft in the meantime.
Nice paint job btw. Are you going to tie in other trim pieces with the same colour?
Anthony wrote:Sounds good. If you are going for just springs then Eibach Pro-Kit is your best bet by far. They only lower around 30mm though and this may not be enough for what you want.
Personally I wouldn't go straight for coilovers if you don't plan on slamming it. A nice suspension kit would give you a great result in looks and handling. They are also alot more straight forward to fit and setup.
thedools wrote:Looking nice M055Y, you need to paint your brake calipers to match also
did you get your shark fin off flea bay? Ive seen em on there but not sure of the sound quality.
Looking forward to the pics of it lowered and bumpers on!
