High level brake light
- Currently Drives:: 2003 Renault Megane Privilege 2.0l petrol, in metallic black
Mines not working at all. Anyone happen to have one going? Or does anyone know if theyre expensive from renault?
- Currently Drives:: Renault dealer so all kinds of Renaults!
Re: High level brake light
Good afternoon
Please email me at pte@fish-bros.co.uk with your vehicle reg number or chassis number and I can offer you a discounted price on the genuine Renault part
Thank you
Paul Temperton
Renault Parts Direct
www.renaultpartsdirect.co.uk
Thank you
Paul Temperton
Damo2580 wrote:Mines not working at all. Anyone happen to have one going? Or does anyone know if theyre expensive from renault?
Theres really not that much that can go wrong with them.
Its only a plastic housing and a bulb holder. (unless its an LED unit)
Just check the bulb connections are tight (and the bulb hasnt blown)
If you have a multi meter check its getting power.
Its not a part that needs 'replaced' any problem will be easly fixed.
Any other questions just ask.
ulrich100 wrote:Damo2580 wrote:Mines not working at all. Anyone happen to have one going? Or does anyone know if theyre expensive from renault?
ive had the strip out as i thought it could be the bulbs blown and needong changing but it has little led lights so i cnt just change tem would have to be a whole new strip. Ive not checked the connectors so will do that. Ive had to replace a brake light and number plate light since last week so cud hav just blown.
- Currently Drives:: renault megane tourer estate
hi i have a megane estate and my rear led light is not working at all i need to new led unit and the plug on the back of it any one no where to purchase this un it finding it very hard throu any kind of breaker yards
Just go onto ebay and buy a 48 LED strip for around a pound.
Then cut to length.
Then cut to length.
- Currently Drives:: Megane 1.5 dci black, tinted , powdercoated black alloys :)
Mine doesn't work must be a fault or cheap part used ! I found then on ebay but there 35quid rip off only 3leds and bit of plastic.... Good idea with the strip I'm going to take mine off and glue the strip inside the current unit
black 3door megane 17" black powder coated renault alloys tints headunit and 12 edge sub....... Wants all smoothing hids
lowering sport interia sport frount bumper then I'm sorted:)
When mine failed I just removed the trim and saw that the circuit board had become loose due to bad soldering. 10 minute fix.
Worth noting that it is not a requirement for the UK MOT test for it to work - provided both side brake lights are operational.
davelowe wrote:When mine failed I just removed the trim and saw that the circuit board had become loose due to bad soldering. 10 minute fix.
Thats handy to know, if its not a requirement i won't rush to get it replaced. Might just look around some scrapyards and see if i can locate one! Renault want £49.50 for it. I think not for a brake light!
The other 2 work so it isn't desperate!
