any help etc is much apprieciated!! thanks!
and this is it today after a good clean!
R55VYS wrote:id fit a snow plow to the front, and a big wing in the middle of the roof, and maybe some pram wheels, and a massive graphic of a dildo down the side.
rustyDLK wrote:R55VYS wrote:id fit a snow plow to the front, and a big wing in the middle of the roof, and maybe some pram wheels, and a massive graphic of a dildo down the side.
forget the massive graphic of a dildo i could just set you on my roof it would give the same effect!!
R55VYS wrote:Honestly though, the fun in doing stuff to your car is sorting the stuff yourself, and making it look different from the rest.
Id say to start though.
Lower it - any spring, you dont need to change the dampers, ive got spax -45mm on, they've been on since i got the car and i have no complaints, normal roads and motorways arnt a problem, its bumpy little backroads that i unfortunatly drive down every day which is the ball ache.
Yes you can lower it 50mm on the 16s still, the 18's you'll be looking at will be exactly the same size as the 16s just less tyre, 225 40 18, dont go lower it looks kack, would be nice to have 225 45 18 on but that will throw your speedo out slightly but they will fit easy and will give you a nicer ride.
Colour code, Smoked side repeaters, paint your ren badges, silver indicator bulbs for front lights, HIDs, Shorter Aerial, put some front fogs in, Black rear lights (i might just know where theres some cheap ones) shamless plug ha ha. tints, paint your calipers, silver door handles from higher spec models. Spoiler. I could go on an on, totally depends on what you want to spend, and what you like. whether your trying to tidy it up or make it into a max power fiberglass shed.
Eddie-- wrote:really lol i never knew
yes if you go lower than 45 your shocks wont last long specailly with the way armagh and portadown roads are
Eddie-- wrote:you bought a new car for an axle lol axle are buttons till get lmao
Users browsing this forum: Google Adsense [Bot] and 18 guests
