Fridge
Re: Fridge
oops, this is the link to what i found http://www.firststopsolar.co.uk/peltier-thermoelectric-cooler-element30mx30mm-68-p.asp
- downsyndromedhorse
- Currently Drives:: 3DR Black 1.9dci Megane 04 Plate 120 BHP
Re: Fridge
That product in the link probably wouldn't be great, it would get very hot on one side.
The components from the fridge would be the best bet.
You could literaly just make the armrest work in the same way as the case would. However the issue your facing is how much space your left with.
You could try and get the cooling components inside the cavity in the arm rest, in between the double skin. That way you'll be saving space inside.
Dont think the Glove box thing would work, mine doesn't get that cold either and the pipe would need insulating all the way to the armrest.
Re: Fridge
Got the armrest today, just got to get all the bits together and work out how to put it all together, I bought one if those things in the link, it's amazing how cold it gets in just a few seconds I'd frozen my finger to it! No joke, and used a heat sink from a pc to dissapate the heat, just got to work out how to fit it all together, thinking of attaching a metal plate to the cold bit to increase the cold surface area and therefor cooling mor air within the compartment... What do you think??
Re: Fridge
How big is the area on the plate?
You could cut a piece to fit the bottom of the armrest, that would spread the cool area as much as you could.
How are you going to get rid of the heat?
I assume your going to mount this on the bottom of the arm rest?
Whats your plan for the 12v feed? Any idea where you can run it from to make sure its off when the engine is stopped?
You'll want to make sure that plate doesnt get too cold, it is going to be in a small space and will make it extremely cold inside.
Re: Fridge
got it ll fitted in the car now, its working ok, but the heat the thing produces is kinda counter acting the cool!lol so it will be needing some more insulating, tbh now all its got is silver foil, which will be doing f all!
i took the 12v from the cig lighter, i just split the original wires on their way to the socket, works well..
so far im happy with it, bar the fact its not so efficient, but that will hopefilly be put right when i add some more insulation.
i will pop some pics up if your interested, im amazed how nicely it all fits, just seems as tho its meant to be!!
oh, one thing i found was a fuse kept blowing as i put an inline switch in so i could put the fridge off,(it does go off with the ignition as it is but i wanted more control) and every time i switched it off it blew the fuse.... not too sure why, i even tried adding a diode, but that didint stop it. anyways i have now removed the switch and it just goes on and off with the car, which is good enough i guess! oh and no blowing fuses..
Re: Fridge
Nice one, yeah definitely get the pics up.
Can you not squeeze a fan in to get the hot air out?
Well done, i'm impressed!
Re: Fridge
not to put a downer on your project here but is all this not a bit of a waste of time? surely it will only worked when the car is switched on? and if not it will drain your battery.
Re: Fridge
well, i guess, kinda.. but tbh im not exactly trying to put my house fridge out of buisness! just wanted to use it for long journeys, travelling to spain next month n really done it just for that!
Re: Fridge
joeishmather wrote:well, i guess, kinda.. but tbh im not exactly trying to put my house fridge out of buisness! just wanted to use it for long journeys, travelling to spain next month n really done it just for that!
Ah i see, i should really have read all your posts. I just thought you'd been watching to much pimp my ride ha ha
Re: Fridge
fridge isnt working so well, i think the plate i made is too small, and the heat generated by hot side isnt really escaping anywhere, so the surrounding area gets rather warm which takes away from the cold.
im getting a larger plate cut to connect it to and this should help, i have also nicked some super insulation stuff which will hopefully stop the heat transferring!
i'll keep this updated as it progresses!lol
