Engine upgrade
MArkyB
Currently Drives:: 54 Megane CC 2.0 VVT
06 Megane Scenic 1.4 Dynamique
Engine upgrade
Postby MArkyB » Tue Apr 13, 2010 1:08 pm
Hi all, newbie here
Can anyone tell me if you have sucessfully installed a RS225 engine in a CC?
Also, can you marry it to a 2.0 auto box?
Potential future project.....
Re: Engine upgrade
Postby wanda » Tue Apr 13, 2010 7:27 pm
I am not sure but I have thought of installing a written off megane cc 2.0dci engine into mine but am still saving up for it.
MArkyB
Re: Engine upgrade
Postby MArkyB » Sun Apr 18, 2010 12:19 am
No-one's put a 225 engine in a CC? There must be someone out there?
Re: Engine upgrade
Postby Anthony » Sun Apr 18, 2010 8:53 am
MArkyB wrote:No-one's put a 225 engine in a CC? There must be someone out there?
It is a bit of a long shot really. The majority of Megane owners won't ever lift the bonnet. Your typical CC driver... even less chance!
I have never heard or seen of an engine swap but that is no reason for you not to try it first. Be a pioneer!
jak01
Currently Drives:: Megane 1.6 CC Vectra 1.9 cdti (Company car) MGB
Re: Engine upgrade
Postby jak01 » Sun Apr 18, 2010 5:43 pm
I think it would require a bit more than lifting the bonnet!! :)
Off the top of my head you would need:
Complete engine/gearbox/diff assembly
All associated induction and exhaust for the above
ECU
Uprate Brakes and suspension
And the ability to spend a lot of time and money and probably end up with something that is worse than what you started with. More power does not necessarily mean more fun.
Once you got it all fitted, managed to get someone to insure it -hope the chassis does n't twist itself to destruction. :eek
My 1.6 CC as massive scuttle shake with the roof off and if you give it some beans on the bends the screen surround twists between the door windows.
I love my car, but it's a comfortable tourer, definitely not a sportscar.
John
Ford Mondeo, 1.6 vvt CC Privelege, 1973 MGB
Re: Engine upgrade
Postby Anthony » Sun Apr 18, 2010 10:24 pm
That's the point I was making. That most megane owners won't give a damn about what happens under the bonnet, never mind consider changing an engine!
MArkyB
Re: Engine upgrade
Postby MArkyB » Tue Apr 20, 2010 7:03 pm
Thanks for the thoughts guys. I had also considered all the things you mentioned jak01, that's why I was hoping someone might have already pioneered the swap, to get an idea of the pitfalls, and if indeed it is possible.
