megane 1.6 injection problmes
Conor Megane
Currently Drives:: renault megane 1.6 sport
Postby Conor Megane » Tue Apr 13, 2010 7:30 pm
right had a check on the car and there are problems witht he car
it has injection problme
checked injectors sparks
coudl it be the coils and if it is worth changing the injectors and sparks aswell
and does any of it need coding before it will work properly
also how would i know if the car is running on limp mode ??
conor
Re: megane 1.6 injection problmes
Postby davelowe » Tue Apr 13, 2010 10:29 pm
It won't rev above 3000 rpm (or thereabouts) if in limp mode.
Conor Megane
Postby Conor Megane » Wed Apr 14, 2010 8:50 am
`right ok then no it revs above 3000 so it cant be that problem
Postby davelowe » Wed Apr 14, 2010 10:30 pm
Petrols aren't my thing. If the throttle body is clean, then I'm afraid I can't help. Hopefully someone more experienced will chip in.
Conor Megane
Postby Conor Megane » Thu Apr 15, 2010 11:12 am
right so how will i go about clenaing the throttle body is this somethign that cause the injectrion problem
markren2004
Postby markren2004 » Thu Apr 15, 2010 6:24 pm
Users browsing this forum: Google Adsense [Bot] and 33 guests
