Hands free: button not working on door to lock car
mrmartyn1984
Postby mrmartyn1984 » Sat Mar 20, 2010 8:10 am
Hi all,
Our Megane's hands free isn't working properly. When you push the button on the drivers door nothing happens :-( any ideas how to fix this? Other button is working as is the one on the boot. Unlocks fine.
Cheers,
Martyn
MéganeDynamique
Re: Hands free: button not working on door to lock car
Postby MéganeDynamique » Sun Mar 21, 2010 1:13 pm
My Mégane did this in the winter when it got really cold, but it cured itself when it got above around -3 degrees.
You could remove the handle and check the connection?
bigyellataxi
Currently Drives:: 03 Megane Priv (well SWMBO does..)
55 Ford Zodiac, 302ci powered...
Postby bigyellataxi » Sat Mar 27, 2010 6:59 pm
WD40, sprayed into the button with the straw, the gently lever out the button with a scalpal blade and re-WD40...!!!
I now just lock ours with the boot switch...
rteone
Currently Drives:: 2003 scenic dynamique+,2003 megane 1.5 dci expression
Postby rteone » Sat Mar 27, 2010 7:22 pm
mine did the same.i got a new button kit from renault,only cost about £15 but you have to remove handle to replace.
