upgrades
matttingle
Currently Drives:: 1.9 dci dynamique, 2004, ottoman, panoramic roof, 6xcd,
upgrades
Postby matttingle » Mon Mar 01, 2010 1:12 pm
currently my 2004 megane is standard, 16" nervastella, grey bumper inserts etc...
i'm planning to;
upgrade to 17" pro race 1.2's in black with 225/45/17 tyres
take out grey bumper inserts, sand, prime and spray to match body colour
put spax lowering springs to drop it by 30
any thoughts / ideas on these mods???
1.9dci 04, ottoman, panoramic roof, black 17" pro sport 1.2's,
redmeganematt
Currently Drives:: renault magane vvt 1.6.16v
Re: upgrades
Postby redmeganematt » Wed Mar 03, 2010 6:55 pm
sounds good im doing the same but having nervasprot alloys. put the meg on eibachs instead of spax the ride quality is better all round and the drop the same.
2005 3 door 1.6 vvt in flame red. eibach springs -30mm. 17" nervasport alloys
Re: upgrades
Postby Paddy » Thu Mar 04, 2010 12:13 am
matttingle wrote:currently my 2004 megane is standard, 16" nervastella, grey bumper inserts etc...
i'm planning to;
Forget the Spax springs if you value comfort. I had a pair that dropped it 30mm. I got rig of them and bought Ebachs that droped it 60mm and the ride was more comfortable than the spax not to mentino better going round a bend. In the end got rid of the ebach springs and bought ebach coilovers. Now i ride with an 80mm drop or there abouts ( arse on the ground) and hardy fell a bump... well so to speak.
Have to keep a spare CV joint in the garage but its all good!
So if your only buying springs look at Ebach or if there to expensive look at Koni. Avoid Spax and PI well IMO.
matttingle
Re: upgrades
Postby matttingle » Fri Mar 05, 2010 12:19 pm
thanks...
Koni are defo cheaper option, would you say best option for the price???
redmeganematt
Re: upgrades
Postby redmeganematt » Fri Mar 05, 2010 4:07 pm
i would defo go for eibachs at the end of the day its your car. i would rather spend that little bit more n no they are going 2 be up 2 the job. but its up to you pal what ever suits your budget.
guy1988
Currently Drives:: Renault megane 1.9DCI
Re: upgrades
Postby guy1988 » Fri Mar 05, 2010 4:17 pm
i'm planning to;
WOW 80mm drop is that on your megane?
have you got any pictures?
im thinking about dropping mine to 50/60mm on Vmaxx coilovers
whats the ride qaulity like on an 80mm drop?
Re: upgrades
Postby Paddy » Fri Mar 05, 2010 10:51 pm
Ill throw up one or two pics,
The ride quality has suffered a tad, but due to the strengthened dampers its perfectly acceptable.
-75/80 (mm) is perfectly acceptable on 17's. Although mid weeks i cant ride that low. Speed bumps are incorporated in my journey.
matttingle
Re: upgrades
Postby matttingle » Tue Mar 09, 2010 10:24 am
wheels have been ordered! hopefully arrive this week
if i swop the valves from current tyre to ne ones will this retain tyre pressure monitor??
lexhardon
Currently Drives:: Megane sport hatch 2.0 16v 136
Re: upgrades
Postby lexhardon » Sun Mar 14, 2010 9:16 pm
mattingle,
I swapped my 16 nervastella to 17 nervasport and exchanged valves to maintain tyre pressure monitors no problem!!
hope this helps
matttingle
Re: upgrades
Postby matttingle » Tue Mar 16, 2010 12:43 pm
wheels have now been put on......what a difference!
team dynamic pro sport 1.2's with 225's, can really feel the difference....
next job will be to lower it
guy1988
Re: upgrades
Postby guy1988 » Wed Mar 24, 2010 11:46 am
ulrich100 wrote:Ill throw up one or two pics,
Can you put those pics of you motor up for me please.
im dying to see a meg dropped 80mm
M055Y
Currently Drives:: 57 plate, Renault Megane, 1.5dci
Re: upgrades
Postby M055Y » Wed Apr 28, 2010 1:55 pm
As above
57 plate, Renault Megane, 1.5dci and only £30 per year road tax!
R55VYS
Re: upgrades
Postby R55VYS » Thu May 13, 2010 1:17 pm
Meg dropped 80mm on 19s, its a 225 so its 25mm lower than standard anyway
M055Y
Re: upgrades
Postby M055Y » Thu May 13, 2010 6:51 pm
Nice
rickesh
Currently Drives:: 1.9 dci privledge
Re: upgrades
Postby rickesh » Thu Aug 19, 2010 3:25 pm
matttingle wrote:wheels have now been put on......what a difference!
did you change your tyre pressure monitors over? was it easy enough?
Users browsing this forum: Google [Bot] and 16 guests
