megane 225 phase 1 front bumper fit DIRECTLY to 1.5 dci?
nibbles
Currently Drives:: williams and meggy
Postby nibbles » Tue Dec 15, 2009 7:36 pm
will a phase 1 megane sport 225 front bumper fit directly to a 1.5dci without needing new clips or new headlights and griles?
and where can i source front and rear 225 phase 1 bumpers to fit my megane?
thanks
pete
Ray
Re: megane 225 phase 1 front bumper fit DIRECTLY to 1.5 dci?
Postby Ray » Tue Dec 15, 2009 8:11 pm
search the site. the answer is yes and no. yes it fits but you need to mod other things like wiring etc
R55VYS
Postby R55VYS » Wed Dec 16, 2009 1:15 pm
if your 1.5dci is a phase 1 it is a direct replacement, the fogs are the same, no need to do anything to wiring, and all of the clips are the same, the only thing you will need to buy is two fillet pieces which connect the bumper to the wheel arches, these may already be on the bumper you are looking at, but if not they only cost about £4-5 from renault
Nige
Postby Nige » Sat Jan 16, 2010 12:14 pm
R55VYS wrote:if your 1.5dci is a phase 1 it is a direct replacement, the fogs are the same, no need to do anything to wiring, and all of the clips are the same, the only thing you will need to buy is two fillet pieces which connect the bumper to the wheel arches, these may already be on the bumper you are looking at, but if not they only cost about £4-5 from renault
X2 with the front number replacement part number (lurking around here somewhere) it came with absolutely everything i required bar the front washer jets. I Isoponed these over as it was alot of hassle.
