I've got a 04 Megane, as you know the 02-05 models have that orange backlight on the dials and center console, where as the 55- onwards have the nice suttle ice white colour.
Does anyone have any idea how I could get it to be the same colour if not similar?
Thank you.
Sam
Dashboard Lighting, need help!
- Sadret89
- Currently Drives:: Kia Cee'd 1.6 CRDi
Re: Dashboard Lighting, need help!
swap the clocks from a newer model, thats one way round it
07 Kia Cee'd 1.6 CRDi
Remapped
Remapped
- Sadret89
i dont know if it'll fir because of the little screen in the middle is the same. Have you tried?
change the colour of the bulbs?
- Sadret89
See I dont know about that because in my old mk1 megane I tried that and it still was coming out orange
Sadret89 wrote:i dont know if it'll fir because of the little screen in the middle is the same. Have you tried?
yes i have tried, was a straigh swap, the clocks i had before just had the red car symbol to let you know that a door was open but new closkc had the wee screen and i could then see which door it was.
works just fine, only thing is the mileage will probably be different
Remapped
Remapped
why would you need to update the tax book?
If you go to reno they can set the clocks to the actual milage, meaning there would be no difference, all you'd be getting is a higher trim set of clocks
it doesn't change the perfomance of the car and would change anything on the tax book either would it not?
Remapped
Remapped
you have to ask them, they might say no but then you also tell them its a custumisation and if i was to buy a brand new clock from yourself how do yous propose yous set the new clocks to the current mileage on the car?
then they go ugh, umm, ah?
all there doing is taking a reading from the ECU seeing what mileage it says then updating the clocks.
Remapped
Remapped
i used to have ones from an 06 5dr model
don't anymore, sold it for £20
Remapped
Remapped
