Speedo stays lit up!! Help!
james_west
Postby james_west » Tue Nov 17, 2009 6:52 pm
Hi all, thanks for all your help last time. Since then I have replcaed, cam sensor, crank sensor, both front abs sensors, and replaced a couple of blown fuses!
Every thing seems ok, but now it says electrical fault!, think the code is p0530. The only problem I can see is that the speedo stays lit up even when the car is locked! Any one got any ideas? I have checked all fuses, and checked the fuse box near the battery, and it is dry as a bone. I have read on some links and and think it could have something to do with it having a new window screen fit?
The megane is a 2003 1.6 dynamique with 72,000.
Please help guys!
thanks.
Re: Speedo stays lit up!! Help!
Postby davelowe » Tue Nov 17, 2009 11:09 pm
The only reference I can find for p0530 is 'A/C Refrigerant Pressure Sensor "A" Circuit'. Probably total bollocks, but might be worth checking if the A/C works.
james_west
Postby james_west » Tue Nov 17, 2009 11:15 pm
Ah, that makes sense, aircon has no gas in! so thats that code solved. Any ideas for the speedo staying lit up? thanks
Postby davelowe » Wed Nov 18, 2009 4:01 pm
Hmmm... the wiring diagram suggests that the interior multiplex module and a/c systems are linked. The lack of refrigerant may be messing with the 'brain'. Make sure the a/c switch is off. When you get it re-gassed the problem with the speedo light might just go away.. Worth a shot since you need to fix the a/c before the lack of lubrication buggers up the compressor.
