Automatic Wipers
wing
Currently Drives:: 2003 Megane Privilege 16v, 1997 Goldwing, 2001 Focus 1.8
Automatic Wipers
Postby wing » Sat Nov 07, 2009 11:29 pm
Just got a 2003 Megane and the Automatic Wipers ( Rain Sensor ) and the intermittant wipers do not work but the slow and fast wipers do,
Should I be checking an fuse or relay 1st, if so where are there
-KJ-
Currently Drives:: Mégane II Ph.1 1.6 16v Dynamique Luxe, full leather seats, Carminat Informé 1 with CD-changer.
Re: Automatic Wipers
Postby -KJ- » Sun Nov 08, 2009 11:36 am
Your car doesn't have manual intermittent wipers! Just auto+normal+fast. Did you try to change the sensitivity of the rainsensor by turn the dial on the wiperstalk? 1raindropsymbol: not so sensitive; 4 raindrops; max. sensistive.
wing
Postby wing » Sun Nov 08, 2009 1:42 pm
I have try the 4 setting on the stalk and the wiper will go once only and then stop.
You have four positions on the stalk and the last two are normal and fast, so which position is the auto setting
Toolster
Currently Drives:: MG ZR until Sunday then 1.9 DCI 54 plaqte Mehane
Postby Toolster » Sun Nov 08, 2009 3:49 pm
Push the wiper stalk upto the top then click it down 1 postition, Thats the auto setting
wing
Postby wing » Sun Nov 08, 2009 7:26 pm
I have push the wiper stalk up to the top then click it down 1 postition,
andI have try the 4 setting on the stalk and the wiper will go once only and then stop
MéganeDynamique
Postby MéganeDynamique » Sun Nov 08, 2009 7:31 pm
Ok, the wipers sweep once when you turn the ring to confirm that the sensor has been made more sensitive.
You must have tested this when it was not raining.
Put the wiper stalk right to the top. Then move it down one position, this is the automatic position. The wipers should swipe once. Either do this when it is raining, or if not, get out and pour some water over the rain sensor (located at the top of the windscreen, behind the rear view mirror). The wipers should go. If they do, they are working fine!
When in the auto position, the wipers will not go unless it is raining. I've got into the habit of activating the rain sensor everytime I get in the car by moving the stalk up to zero, then to auto again. One swipe, then they'll start automatically if it rains.
wing
Postby wing » Sun Nov 08, 2009 11:00 pm
It is the same sensor for the rain sensor and headlight, because some time the headlight will come in bright sun light
Gav
Postby Gav » Mon Nov 09, 2009 12:18 pm
As far as I know it's the same sensor.
Has the windscreen ever been replaced? If done incorrectly then there can be problems.
wing
Postby wing » Mon Nov 09, 2009 1:54 pm
I am not sure about that because I have only had the car for two weeks.
Also just got a quote to supply and fit the new sensor ( £150 )
chris-wills
Currently Drives:: 2004 megane 1.6 dynamique
Postby chris-wills » Mon Nov 09, 2009 8:15 pm
wipers must be activated each time you switch on ignition. if you leave them in auto position they will not work until you push stalk to top position then move it to the next setting.
direstraits
Laguna III Ph2 Exception
Postby direstraits » Mon Nov 09, 2009 8:54 pm
chris-wills wrote:wipers must be activated each time you switch on ignition. if you leave them in auto position they will not work until you push stalk to top position then move it to the next setting.
It doesn´t work that way on mine. If stalk is in ''auto'' position, wipers activate every time there's rain on the windscreen. You don't need to turn them on every time you start the car. Mine is PhII, btw.
Reno
Postby Reno » Tue Nov 10, 2009 10:04 am
Got the same problem - It was the "Gel pad" in the Rainsensor that one that stick to the front window,, very importent too fix it right - maybe your window had been changed...
Good luck...
Renault Megane II Touring 1.6 16V `04
markren2004
Postby markren2004 » Tue Nov 10, 2009 12:18 pm
My 2004 you need to reselect Auto wipers each time you start the car (even says so in the manual), so must be a facelift "improvement" that renault did ?
-KJ-
Postby -KJ- » Tue Nov 10, 2009 4:29 pm
My 2004 you need to reselect Auto wipers each time you start the car (even says so in the manual).
Same here for my 2005 (pre-facelift).
wing
Postby wing » Wed Nov 11, 2009 5:10 pm
Hi All
Just had a new Sensor and all working well and it cost £114.
Thank you all for the help
Users browsing this forum: Bing [Bot] and 69 guests
