sub connected to standard radio
talbotvilla72
Currently Drives:: Megane Sport Tourer and Corsa
Postby talbotvilla72 » Sun Sep 27, 2009 7:37 pm
Is it possible to connect a sub to the update list radio ?
Anyone done this?
longtallted
Currently Drives:: 2005 Megane 1.5 Dci 5 Door Authentique in Platinum. Mods: TQ-131 Speakers, Aux In cable.
2005 Megane Gran Scenic 1.9 Dci in black. Mods: Aux In cable.
Re: sub connected to standard radio
Postby longtallted » Mon Sep 28, 2009 11:44 am
I think it explains on another thread that some amps (or subs with integrated amp) can take speaker level input but that the sound is not that great. You would most likely disconnect the rear door speakers and use that feed redirected to the sub. I'd be interested to hear what it's like and compare it to the sound from a head unit that's got a proper sub out.
I'm holding fire until I can afford a decent head unit and then do the sub, but I would want to keep the steering wheel audio controls which is a bit of extra to think about. As a test, I tried not using them on the drive to work and realised that I use them a lot, so I definitely want to keep them.
The Master of Mild Mods! :-P
2005 1.5 Dci 5 Door: TQ-131 Speakers, Aux In cable, upgraded interior door handles and central dash, mock carbon fibre gear knob off ebay, leather gear gaiter and silver sprayed surround.
Postby davelowe » Mon Sep 28, 2009 3:01 pm
talbotvilla72 wrote:Is it possible to connect a sub to the update list radio ?
Anyone done this?
Its possible in theory. As mentioned above, you could probably take a feed from each of the rear speakers, make yourself a simple circuit board to combine the stereo into mono using some resistors and op-amps to isolate everything and reduce the voltage from around 6Vac (assuming the existing speakers are 4ohm) to 0.775Vac peak to peak which is the normal input for a line in socket and then feed that into a standard sub amp and speaker box. Or instead a standard amp with your own band pass filter (more fun with op amps and a few capacitors and resistors!).
If you know a little about electronics it should be doable. I might even design a circuit myself although I have very little interest in all that banging noise!
Worth bearing in mind is that you won't get much in the way of audible deep bass as the interior of the car has small dimensions (people about 12 feet from the car will), but you will feel the results. Especially in the 20 - 80Hz range. I guess that's the point though. ;)
Boyblitz
Currently Drives:: Megane 225
Postby Boyblitz » Sun Dec 27, 2009 5:46 pm
I do used to do this with a line adapter from halfords. but they stopped selling them.
Looked like this: https://www.caraudiodirect.co.uk/phonoca ... e=googleps but much cheaper. Then you just need to find the wire for the remote signal to the amp. Took me ages to figure out in the ford focus.
Brad
Users browsing this forum: No registered users and 16 guests
