Boost Gauge on 1.9 DCi
LiamG
Currently Drives:: Megane 120 DCi Dynamique
Postby LiamG » Thu Aug 06, 2009 1:02 am
Hi, where do people normally fit boost gauges in Megane's? Ive always wanted to have one for novelty more than anything.
I dont want to drill anything or remove anything really if possible. Where do you route the pipe from engine bay into the compartment?
Looking at a 52mm version of one
Megane II 5dr 1.9 DCi 120 Dynamique in Yellow (yes yellow like the renaultsports) - Now Sold :(
anth_dci
Re: Boost Gauge on 1.9 DCi
Postby anth_dci » Thu Aug 06, 2009 9:45 am
i would also be interested in fitting one of these, but ive no idea where to start
Poddy
Currently Drives:: Kia Cee'd 1.6 CRDi
Postby Poddy » Thu Aug 06, 2009 3:30 pm
I fitted one.
see the front quarter panel. you'll be able to thread the pipe along there to the inside of the car.
07 Kia Cee'd 1.6 CRDi
Remapped
Poddy
Postby Poddy » Thu Aug 06, 2009 3:32 pm
i'll take pics n show u, 'even tho ive no megane the description will still be the same'
Remapped
LiamG
Postby LiamG » Thu Aug 06, 2009 9:02 pm
Brilliant thanks for that, ill wait for the pic as im still not too sure.
Thanks :D
LiamG
Postby LiamG » Thu Aug 06, 2009 10:43 pm
Yeah just thinking of a 15 PSI max one - 52mm
No idea what it would boost to as standard but imagine the 15 would be ok?
Poddy
Postby Poddy » Fri Aug 07, 2009 1:16 am
nope too low, mine boosted to 22psi
Remapped
LiamG
Postby LiamG » Fri Aug 07, 2009 4:21 am
Ahh thanks for that, ill look for ones up to 30 psi then
Just got to figure out what you mean to get it through lol :oops:
LiamG
Postby LiamG » Fri Aug 07, 2009 5:12 am
Does a 120 DCi really boost to 22psi as standard? would of thought it was less for some reason
Any ideas where to mount the pod where i wouldnt have to drill or anything. was thing in the corner of the windscreen near the A pillar just stuck down with some double sided tape or something
Poddy
Postby Poddy » Sat Aug 08, 2009 1:09 am
i'll get the phots up over the weekend as im in work atm.
Remapped
dalefletcher111
Postby dalefletcher111 » Sat Aug 08, 2009 10:43 am
1 bar wouldn't be enough if it boosts to 22psi.
1 bar = 14.5psi
I don't know anything about boost pressures but given 1 bar is normal air pressure I though it'd be higher than 22psi.
2004 1.9dci 120 dynamique 3dr
Poddy
Postby Poddy » Sat Aug 08, 2009 5:39 pm
Standard Subaru's Boost to about 22psi, when a bit of work has been done to them get boost to about 2-2.5 BAR
Remapped
tallpaul
Postby tallpaul » Sat Aug 08, 2009 6:01 pm
i had one on my old 306, the novelty wore off in about a week
