Double Din install
Jasonthejoker
Currently Drives:: 2004 Megane Cabriolet 1.9 dCi
2004 Grand Scenic 1.9dCi
Double Din install
Postby Jasonthejoker » Sun Jul 12, 2009 8:32 am
Hi all. I;ve got me a double din headunit. All electrically installed, but looks shocking at the moment! I've got a 2004 megane CC and have removed the CD player and in-dash changer (Both for sale if anyone interested). I've purchased this http://www.incarexpress.co.uk/view_product.php?partno=CT23RT02A and it will give me the cradle to hold the HU. It wont cover all the gap left though. My old stereo fitted flush. Do I need to also purchase this http://www.incarexpress.co.uk/view_product.php?partno=CT24RT06 to cover the gaps around the edge?
I know there's an excellent post about the brilliant Kenwood double din unit but i thought that only required the bit I've bought. Any help very much appreciated.
Jason
Starman
Currently Drives:: Proton 1.6 Lxi Wira
Re: Double Din install
Postby Starman » Sun Jul 12, 2009 9:36 am
PM sent, from another Jason!!
Postby Paddy » Mon Jul 13, 2009 4:50 pm
What you need is the 'connects 2' CT23RT02.
Heres there PDF
http://www.connects2.com/pdfdocs/articles/dd-kits-low.pdf
It states its for a 06-07 megane but i used it to fit my double din and it was a fantastic job.
You can see it here..
Jasonthejoker
Postby Jasonthejoker » Tue Jul 14, 2009 6:31 am
Thanks. Did that include the plastic surround and double din cage? I bought the CT23RT02A from which the cage fits, but fascia is too narrow to cover the gaps.
Postby Paddy » Tue Jul 14, 2009 5:51 pm
Yea was all that was needed in one box.
• Cage
• Surround
• Brackets to hold it in place.
• Large bits of foam... that I am yet to find a use for.
The cage wouldn’t be in the correct position if the surround didn't fit. I had to put the surround in position first, then the cage went ‘though’ and clipped to it. I then was able to prize down the metal tabs to secure it.
Finally slotted in the radio...
Postby Paddy » Tue Jul 14, 2009 5:55 pm
From a post i made a few months back...
I couple wanted to see a double din in stall.
When the original head unit and multi changer / cubby hole are removed there is a cross bar (plastic strip) that needs to be removed by a hack saw or plastic heat cutter, and then filed.
To the rear of the craves created one needs to cut away the top protruding plastic oval ( this is used to hold the original HU in place.) has to be removed to allow attachment of GPS aerial in my case. ( See pic 4 )
Here you can see the cut away plastic and the spliced hand brake wire, to allow use on the move.
I have used the Connects2.com double din cage. On the website it states it's for the Meagne 2008, but the dash has not changed through 2002 - 2008 and in fact once delivered is labelled 2005 - 2007.
bull20
Currently Drives:: Colt Czt
Postby bull20 » Wed Aug 05, 2009 5:20 pm
Nice post mate, I plan to get a double din into my meg somewhere down the line :)
Has anyone every come across the eonon ones on ebay?
are they just cheap tat or are they any good?
Adam
Postby Paddy » Wed Aug 05, 2009 6:29 pm
bull20 wrote:Nice post mate, I plan to get a double din into my meg somewhere down the line :)
Adam
You get what you pay for lad... There cheep for a reason... Components/GUI (Graphical User Interface) is pish poor.
Your better to save a bit longer and buy a pioneer/alpine etc.
From experience i can tell you if you buy cheep from eBay you will disappointed.
bull20
Postby bull20 » Wed Aug 05, 2009 7:08 pm
Bad times :-( lol must see if I can get my hands on a 2nd hand one then :cool:
