how to fit a renault in dash cd changer under standard HU
mickliane
Currently Drives:: megane cc
Postby mickliane » Fri May 22, 2009 10:18 pm
Hi can anyone help??
i have a 2006 06 megane and have just bought of ebay a 6 disc cd changer from a 2002 model (looks like the later model).
how do they both connect? i have no wires with the cd changer, dont know whats in the dash yet
do i need to buy any cables/connectors etc?
im out on a limb here.
is the 2002 model no. MH9RN020 compatible with the standard radio cd in my renault? (2002 into 2006)
HELP!!!!!!!!!!!!!!!!!!!! :-)
ace
Re: how to fit a renault in dash cd changer under standard HU
Postby ace » Sat May 23, 2009 10:01 am
Hi!
You need to buy an interconnect cable between your HU and CD changer.
I got it from my local dealer for 35€. This is all you need for your changer to work properly. The illumination is not "transfered" through this cable, so you will have to hotwire something by yourself.
Here is a thread where I got plenty of info on my CD changer.
Ray
Postby Ray » Sat May 23, 2009 7:18 pm
also the illumination is different. 2002-2005 models have amber lighting. 2005> have the white lighting
Starman
Currently Drives:: Proton 1.6 Lxi Wira
Postby Starman » Wed Jul 01, 2009 10:04 pm
Hi there.
Did you manage to get the changer fitted and working ok? I'm about ot do the same. I've bought a second hand changer, obtained a code. Just need the cabling now, I think! Anything I should look out for???
Cheers..
J. :D
ace
Postby ace » Thu Jul 02, 2009 11:47 am
Hi!
The fitting is really easy. Straightforward.
The only "problem" I had, was when I fitted the changer, connected everything, and changer didn't work. The problem was, the connection cable has some kind of a lever on the changer side (so everything stays in place). I pressed the lever and changer started scanning for CDs and asked for the code.
Nejc
