Hi all,
Cooling system on my 225 is ready to be changed,
on re-fill does the system need to be bled of air like most other french cars.
Anyone know
Rich
Coolant Change
- megane09
- Currently Drives:: renault megane '04 dynamique, silver, 17 nervasport alloys.
Re: Coolant Change
hi, i would just check the system for any leaks and make sure there isnt any air in it by bleeding it anyway as with most cars depending upon how you do it , you will probably need to bleed it. matt
'04 Megane Dynamique, 17' nervasports alloys
Re: Coolant Change
Yes, you need to bleed it. Small 10mm bolt in the side of the stat housing. Remove it and replace once a steady flow of coolant can be seen.
Users browsing this forum: Google Adsense [Bot] and 9 guests
