New spark plugs and new horn!
snowy
Postby snowy » Wed Dec 26, 2007 11:12 am
ha! nickbell69 , i think you've been conned! :X-/:
nickbell69
Postby nickbell69 » Sun Dec 30, 2007 12:53 am
He didn't charge me for it which is why i didn't really query it. :cool:
Poddy
Currently Drives:: Kia Cee'd 1.6 CRDi
Re: New spark plugs and new horn!
Postby Poddy » Tue Nov 04, 2008 6:22 pm
I fitted a triple tone horn to my car, but decided not to fit the resister alonge with it, so after about a month of useing the extra loud horn, 'aparently i could be herd from the other side of Bangor NI' the car fuse blew, so just replaced it and it works fine again, all i do is replace the fuse, works wonders, i fitted the horns to the bottom of the bumper so they didnt slide about and so they dont get wet when using a power hose
07 Kia Cee'd 1.6 CRDi
Remapped
Postby Paddy » Wed Nov 05, 2008 10:31 pm
Poddy wrote:I fitted a triple tone horn to my car, but decided not to fit the resister alonge with it, so after about a month of useing the extra loud horn, 'aparently i could be herd from the other side of Bangor NI' the car fuse blew, so just replaced it and it works fine again, all i do is replace the fuse, works wonders, i fitted the horns to the bottom of the bumper so they didnt slide about and so they dont get wet when using a power hose
Bangor NI that my neck of the woods!
What horn was it i like the sound of that...heard from the other side...
Poddy
Postby Poddy » Thu Nov 06, 2008 3:52 pm
U know the Auot Spares in Ards shopping centre, in there, its the Tripple tone horn, would work longer if i bothered to put in the resister, do u float about bangor much then?
Remapped
Postby Paddy » Thu Nov 06, 2008 8:50 pm
Poddy wrote:U know the Auot Spares in Ards shopping centre, in there, its the Tripple tone horn, would work longer if i bothered to put in the resister, do u float about bangor much then?
O aye, i live in bangor, you cant miss me im pretty sure i own the only black megane saloon in the town. Or come to think of it the only meggy saloon for that matter. How loud is it? The horn in the car is sh1t to be frank!
jonbrowne1
Currently Drives:: 04/04 1.5DCi Expression 5 door
Re:
Postby jonbrowne1 » Sun Nov 09, 2008 3:58 pm
cyclonebri1 wrote:
scoop wrote:
IainMW wrote:Is it a bumper off job to fit the horns?
No not at all mate. It was easy in the end when I figured it out. All you need to do is carefully remove the left hand front grill the one beside the badge in the middle. You can then work on the wireing and enough space to get your hands in and fit in place the horns.
Can confirm that, done mine this morning. Will never believe what the manuals say again, bumper off my a**e.
I found it easier to remove both upper grills so able to get both hands in, a couple off thin wide blades, I used 1 1/2" wide filler knives, and you can lift the grills out from bottom first. Apply a bit of masking tape to the paintwork above and below first in case you slip up.
Cheers, :cool:
:-) My horn works like new now. Thanks for the advice.
swift85
Postby swift85 » Tue Jun 09, 2009 5:23 pm
Had a simliar experiance today. Needed a woman to move at a Green light so gave her a quick beep and she didnt even here me.
Therefore im after a new horn. Looked at the Ebay dual tone horns. This may not make sense but i want it to sound like a Car horn rather than an Air Horn do you know if these sound ok?
And if not does anyone know any alternatives.
Thanks.
steve the postman
Currently Drives:: 1.5 DCI 86 EXTREME TUNING BOX
DAB DIGITAL RADIO/DVD PLAYER
HID HEADLIGHTS
PIAA HORNS
GT LEATHER STEERING WHEEL
Postby steve the postman » Wed Jun 10, 2009 8:43 pm
I use PIAA horns bought from https://www.motaman.co.uk/Product.aspx?nCatId=137
you do not get missunderstood
Steve
Postby Paddy » Thu Jun 11, 2009 9:29 pm
I would suggest the Stebel Nautilus
http://www.stebel.it/stebel/index2009.htm
They are a compact twin horn design made in italy.
Have a great sound and are reated at 115DB at 3 meters.
I have had one for about 3 months and from experiance they do the perfect job of getting folk out of the way.
It was about £20 form the bay.
dalefletcher111
Postby dalefletcher111 » Wed Jul 15, 2009 8:00 pm
i know this is an old thread but im currently looking at a stebel nautilus on ebay.
Just wandering:
1. ulrich how is the horn going?
2. did it fit in the same place as the standard horn?
3. did you do anything with wiring? the nautilus says it needs 20amp wiring??
4. had any problems like poddy with fuses blowing?
thanks
Dale
2004 1.9dci 120 dynamique 3dr
dalefletcher111
Postby dalefletcher111 » Wed Jul 15, 2009 8:02 pm
Also anyone had problems passing MOT's with the louder horns?
MOT regs state the horn can be rejected if "a sound emitted by the horn is- not a constant note- not continuous or uniform- harsh or grating"
Obviosuly i want my horn to be very harsh lol :cool:
also nickbell69, it seems he was doin you a favour. It can be rejected if "the sound emitted by the horn is not loud enough to be heard by another roaduser"
https://www.ukmot.com/6-2.asp#Text_top
Last edited by dalefletcher111 on Wed Jul 15, 2009 8:10 pm, edited 1 time in total.
Postby Paddy » Wed Jul 15, 2009 8:08 pm
Had it a few months now and not a problem,
It was a direct fit. I just striped the existing cable and soldered it to the points and has work fine.(Make sure you get the cables the correct way round.) It came with a relay ect but i couldn't have been bothered with that so binned it!
Its a bumper off job. Wont fit through the grill.
Its loud and is a great replacment. The next step up would require a compressor etc to be any louder IMO.
LiamG
Currently Drives:: Megane 120 DCi Dynamique
Postby LiamG » Fri Jul 17, 2009 5:53 pm
So its not just my horn that is embarrasing! Glad to know. I might get 4 or 5 of these air horns just to make a point hehe :roll:
Ive just got the dealers to replace mine, waiting for it to come in. Will i have the same problem with the standard replacement horn?
Megane II 5dr 1.9 DCi 120 Dynamique in Yellow (yes yellow like the renaultsports) - Now Sold :(
Postby Paddy » Sat Jul 18, 2009 2:40 pm
LiamG wrote:So its not just my horn that is embarrasing! Glad to know. I might get 4 or 5 of these air horns just to make a point hehe :roll:
yea,the sandard horn is rated at only 60DB. I dont think that would wake me up from a sleep never mind get someone out of my way. An aftermarket one is the way to go.
