wheels
mystik biskit
Currently Drives:: 2002 renault megane 2.0 16v dynamique
wheels
Postby mystik biskit » Sun May 24, 2009 2:48 pm
hi all was wondering what the biggest wheels r i can fit on my megane without any arch work??
ICEMAN
Re: wheels
Postby ICEMAN » Tue May 26, 2009 10:25 am
22 inch
IrvinsMegane
Currently Drives:: Renault Megane 1.6 16v VVT Dynamique,
Re: wheels
Postby IrvinsMegane » Tue May 26, 2009 4:36 pm
That Cant be Right, Can It?????????????
dalefletcher111
Re: wheels
Postby dalefletcher111 » Tue May 26, 2009 6:37 pm
Given these are 18s:
viewtopic.php?f=13&t=10217
i think theirs def 2 inch gap on each side of the wheel.
does anyone know if 22s would rub under full lock? or is this the biggest size that dont rub?
2004 1.9dci 120 dynamique 3dr
Poddy
Currently Drives:: Kia Cee'd 1.6 CRDi
Re: wheels
Postby Poddy » Wed May 27, 2009 1:14 am
it depends on the width of the ally, like you can get 19's that are 7.5" wide then again you can also get 19's that are 9" wide
depends on the alloy
07 Kia Cee'd 1.6 CRDi
Remapped
ICEMAN
Re: wheels
Postby ICEMAN » Fri May 29, 2009 3:05 pm
I WAS F'IN with you guys!! lol
19 but then you couldnt get anyone in othersie there will be some scrapage - UNLESS you install some serious springs and shocks....either way the ride will be shite!!
ive got 18's on mine 225 40 18 tyres and they are fine.
17" are a better ride all round...
boith the 18" and 17" will require some lowering to gt you that nice look!
TheFinn
Re: wheels
Postby TheFinn » Fri May 29, 2009 6:42 pm
mystik biskit wrote:hi all was wondering what the biggest wheels r i can fit on my megane without any arch work??
Can't say what the absolute maximum is, but a 225/35R19 tyre on an 8½x19" wheel (38mm offset) I can guarantee to fit, based on my own experience.
Just found the ultimate tyre size comparer site!
Here's a comparison of the Megane original tyre/wheel size vs. the 19" setup I have:
205/50R17 + 7x17" offset 49 vs. 225/35R19 + 8½x19" offset 38
I hope that site finally helps people to understand the "holy union" between tyre width, tyre profile, wheel diameter and wheel offset.... :roll:
R55VYS
Re: wheels
Postby R55VYS » Sat May 30, 2009 11:04 pm
Theres a few megs with 20's on, ther eall sports tho so you may struggle finding them for a standard one, the ride quality would be terrible to, you'd feel every little tiny bump in the road.
laguna steve
Currently Drives:: Renault Megane 1.9DCI Limited Edition Sport
Renault Laguna 3LT V6 (Modified/Show Car)
Re: wheels
Postby laguna steve » Sat Jun 13, 2009 3:20 pm
I replaced my origanal 17's for 18,s and then went a brought a set of 20 inc 100+ Jets in black.
They were 225 / 35 / 20 rubber with a 7.5 X 20 wheel
The car was lowered 40mm on springs
They went on but caught the front arches when turning corners, it became a pain and i wish i had got 19,s but hay ho, I am now in the process of getting the wide arch kit fitted and the arch will be cut away and then it will be lowered again by 30mm, I had to fit the standered springs back on for the last MOT
TheFinn
Re: wheels
Postby TheFinn » Sun Jun 14, 2009 10:59 am
Eddie-- wrote:get the arches rolled solves this :D
A bit difficult rolling a front arch made of plastic innit? :roll: ;)
laguna steve
Re: wheels
Postby laguna steve » Mon Jun 15, 2009 8:39 pm
yeah i minded that later one :-(
but you could grind a bit off them or mould them around it easy done just need a respray on the wings after though
Cut them away and fit the wide arch kit is the only way forward
R55VYS
Re: wheels
Postby R55VYS » Tue Jun 16, 2009 11:28 am
have you tried just removing the arch linings?
laguna steve
Re: wheels
Postby laguna steve » Fri Jun 19, 2009 7:14 am
R55VYS wrote:have you tried just removing the arch linings?
What arch linings??
The 20,s are not a problem at the rear its when you turn a corner where the tyre is directly under the front arch, hit a bump and it bounces up and hits the plastic arch, as for the arch linings, they have been worn away by the tyres.
I wouldent recomend 20,s on a megane unles ur prepared to a little arch work, stick with 19,s its less hassel, "I KNOW"
tallpaul
Re: wheels
Postby tallpaul » Thu Jun 25, 2009 8:20 pm
i reckon that red one must scuff at the front. plus it looks daft.
R55VYS
Re: wheels
Postby R55VYS » Fri Jun 26, 2009 7:39 am
and it would fail mot's over here as the wheels protrude out of the arches.
There was a few that had 20's on that didnt look so daft, black 225 from abroad and a silver one with audi looking wheels on, cant find the pictures now tho.
Users browsing this forum: Google Adsense [Bot] and 28 guests
