Spare wheel
Spare wheel
Postby wanda » Tue Apr 14, 2009 10:23 am
Has anyone got rid of the tyre kit and put in a full size spare wheel?
DAZZA
Currently Drives:: magane cabriolat cc extreme
Re: Spare wheel
Postby DAZZA » Mon Apr 27, 2009 5:07 am
hi yes i put 16 " wheel in well but you have to cut the recess ouy of the carpet or it sticks up
magane cc 1.6 extreme
Re: Spare wheel
Postby wanda » Sat May 02, 2009 6:15 am
nice where did you buy the spare? I heard a space saver wheel from Honda can actually be used and fits in the boot easier.
DAZZA
Re: Spare wheel
Postby DAZZA » Tue May 12, 2009 9:02 pm
got it from renault breakers £30
Re: Spare wheel
Postby wanda » Fri May 15, 2009 7:31 pm
this is a silly question but have you made sure it fits? I heard it takes 5 bolts, nutts or whatever its called
DAZZA
Re: Spare wheel
Postby DAZZA » Mon May 18, 2009 7:41 pm
yer fits great only 4 studs easily snapped though as i found out oops
Re: Spare wheel
Postby wanda » Mon May 18, 2009 8:13 pm
cool. Thanks. I will hunt for mine
faffer
Currently Drives:: Qashqai, Alfa Ph2 Spider & company Octavia
Re: Spare wheel
Postby faffer » Tue May 26, 2009 4:08 pm
I have acquired another Kubera alloy wheel (dynamique 16") for ours. More for putting on the car when the punctured wheel is in for repair. I do have another kerb damaged Kubera alloy that needs cosmetic attention, so looking for refurbish recommendations ideally Essex.
faffer
Re: Spare wheel
Postby faffer » Wed Jun 10, 2009 1:48 pm
faffer wrote:I have acquired another Kubera alloy wheel (dynamique 16") for ours. More for putting on the car when the punctured wheel is in for repair. I do have another kerb damaged Kubera alloy that needs cosmetic attention, so looking for refurbish recommendations ideally Essex.
In answer to my own query, I have found a company just a short drive away and have had a pair of wheels refurbed.Very impressed with the quality & service and not too badly priced either.
faffer
Re: Spare wheel
Postby faffer » Wed Jun 10, 2009 1:51 pm
DAZZA wrote:hi yes i put 16 " wheel in well but you have to cut the recess ouy of the carpet or it sticks up
I was having a look through some Renault parts documentation and see that there is a flat boot carpet without the recess available..It was listed as 8200545444 Carpet boot cab3 (the normal recessed type carpet was shown as 8200545442). Currently making enquiries with a dealer on availability and pricing.
DAZZA
Re: Spare wheel
Postby DAZZA » Wed Jun 10, 2009 5:54 pm
thanks will look into it
Re: Spare wheel
Postby wanda » Wed Jun 10, 2009 5:58 pm
DAZZA wrote:thanks will look into it
Let me also know how much it would be.
faffer
Re: Spare wheel
Postby faffer » Fri Jun 12, 2009 8:10 am
I have had a price back from Renault and true to form it is rather high.
"the boot mat is £120.55 inc VAT & is in stock at Renault UK"
In order to research this some more I'd like to look up some earlier part nos.Can someone forward me the info from a Ph1 CC's oval sticker (label) on B pillar. Not the vin number but the other codes..Dave
faffer
Re: Spare wheel
Postby faffer » Sun Jun 21, 2009 11:21 am
faffer wrote:I have had a price back from Renault and true to form it is rather high.
Bump
davet47
Currently Drives:: 06 Megane CC 1.9dCi
Re: Spare wheel
Postby davet47 » Tue Jun 30, 2009 2:22 pm
15" renault steel wheel ( my car has 16" wheels) from a breakers , tyre section is taller than normal 16" wheel so rolling radius is the same; apparently needs to be same because it (Renault dealer quote)" upsets the diff if it's different"(?). Wheel fits ok and only lifts the boot carpet by about 40mm so I'm not forking out £120 plus for a carpet! I've put the jack/tools in a toolroll in the boot.
