steering locked won't start
anth_dci
Postby anth_dci » Tue Mar 10, 2009 7:47 pm
I went to start my tonight and it won't start again! on the dash it says "steering locked" and the service light is on. I'm bloody sick of this car. anyone got any idea why it's doing this? I'm going to take the battery off and give it 10min see ifthat clears it.
pw981
Re: steering locked won't start
Postby pw981 » Tue Mar 10, 2009 7:49 pm
tried wiggling the steering wheel as you press start?
If not, new electric steering column likely needed - not cheap either! Needs coding to the electronics.
2004 Megane II 1.9dCi
anth_dci
Postby anth_dci » Tue Mar 10, 2009 8:16 pm
it kinds looks like the battery is flat, when I lock it the lights are really dim. going to try jumping when my stepdad gets home. it's a good job ive got my aa cover if it is one of those
pw981
Postby pw981 » Tue Mar 10, 2009 8:26 pm
I hope it is just a dud battery.. much cheaper than a new electric steering lock! let us know the outcome - good luck! :cool:
Postby AlexB » Tue Mar 10, 2009 9:23 pm
Is the immobiliser LED flashing?
anth_dci wrote:I went to start my tonight and it won't start again! on the dash it says "steering locked" and the service light is on. I'm bloody sick of this car. anyone got any idea why it's doing this? I'm going to take the battery off and give it 10min see ifthat clears it.
anth_dci
Postby anth_dci » Tue Mar 10, 2009 9:24 pm
well with abit of help shes fired into life. looks like the battery was flat somehow. It shouldnt be a duff battery i only replaced it in decemeber!
ive drove it for 10miles turned it off and back on and it fired straight away so hopefully it wont happen again. But im at my girlfriends now so if it happens in the morning i can ring the AA (i dont have home start).
to top my night off my iphone has died :banghead
pw981
Postby pw981 » Tue Mar 10, 2009 10:20 pm
glad it was "just" the battery! If it happens again, hopefully tracing the drain on the battery or checking to see if its the battery at fault (you never know!) will be easy!
What happened to your iPhone?
anth_dci
Postby anth_dci » Wed Mar 11, 2009 7:54 am
will having the key close the car cause the battery to drain? I parked slighly closer to the house yesterday and it didnt move all day. how would i go about tracing battery drain?
The iphone decided it only wanted to be on the contacts list. would ring people no bother so i held the home button and the power button and it went to a white screen that wouldnt go off :evil: i connected it upto itunes and did a restore and its working great again now.
snowy
Postby snowy » Sun Mar 15, 2009 6:10 pm
THIS HAPPENED TO ME TOO. I SWAPPED THE BATTERY WITH THE CLIO'S AND IT STARTED!. THE STEERING LOCK IS STILL BROKE THOUGH. CAN I JUST CHANGE THE BATTERY? WHAT YOU THINK?
busternlouie
Currently Drives:: '05' Megane 2.0 VVT Dynamique
Postby busternlouie » Sun Mar 15, 2009 6:38 pm
anth_dci wrote:The iphone decided it only wanted to be on the contacts list. would ring people no bother so i held the home button and the power button and it went to a white screen that wouldnt go off :evil: i connected it upto itunes and did a restore and its working great again now.
You must have put it into DFU mode accidentally. Did you keep the home button pressed after releasing the power button?
jo3yb777
Currently Drives:: 2004 54-Reg Renault Megane 1.6 Dynamique Auto Silver
(SORN'd)
Postby jo3yb777 » Wed Mar 25, 2009 10:51 pm
What's DFU mode?
2004 Megane 5-door 1.6 Dynamique
busternlouie
Postby busternlouie » Sat Mar 28, 2009 2:10 pm
What's DFU mode?
hackint0sh.org wrote:The big difference between DFU mode and restore mode?:
DFU mode doesn't boot up the "mac os" on iPhone - therefore it doesn't communicate with iTunes "as much" as in Restore mode and iTunes can't decide to interrupt downgrading the firmware etc.!!
jo3yb777
(SORN'd)
Postby jo3yb777 » Wed Apr 01, 2009 4:09 pm
Ahhh Thank You
