high pitch sound when braking in slow speed....
tobyngan
Postby tobyngan » Fri Jan 23, 2009 8:56 pm
hi every one...... wonder if anyone had the same problem as mine.....
I've got a 57 reg 1.4 just been serviced 2 days ago....... I've got a high pitch sound coming out from the brake at low speed just before the car come to complete stop..... checked the brake pad 2 days ago at the service, just 20%worn.....went back to renno yesterday to have a look on it.....she said: "this is normal sir, it is just the dirt stayed between your brake disc and brake pad, however we can take the brake out to clean it for you, but this is chargeble, but it will happen again in the future anyway.....because the roads are dirty!!!" :no Am i driving in a different road than the others???? how come i can't hear every car have the high pitch sound when they brake???? :banghead
Have anyone had the same problem before????? and how did you fix it?????? pls help........thx :cry
Re: high pitch sound when braking in slow speed....
Postby AlexB » Fri Jan 23, 2009 9:49 pm
Please let us know if you are a DIY person. Otherwise, you'll have to find a proper garage for inspection/repairs and supply EBC GreenStuff pads. These pads do wonders and the car feels much better (read their web site for the explanation). In my experience Renault dealers and many other garages are useless.
essexpunx
Currently Drives:: Megane 11 1.4 dynamique, Renaultsport clio 182
Postby essexpunx » Sat Jan 24, 2009 11:52 am
Hi, typical renault response (it's because the roads are dirty) do they think we're stupid, anyway as with all sqeaky brakes remove pads, clean all the dirt/dust from pads and calipers, re-assemble using copper grease on the back of the pads, this should do the trick at least for a while, and when the pads need changing EBC greenstuff pads are definately worth buying they cost more but offer better braking and last longer, if you don't feel confident in doing the brakes youself try any of the places like Quick fit or ATS etc, hope this helps.
tobyngan
Postby tobyngan » Sat Jan 24, 2009 11:00 pm
thx for your help guys....but I don't think i am gonna do it myself as i won't be able to put everything back in place after i take them out....... do anyone know how much roughly would it cost to get the brake clean????? recommand any garage????? do they do it in kwit fit?????
anth_dci
Postby anth_dci » Sat Jan 24, 2009 11:19 pm
make sure you have a decent amount of copper slip on the back of each pad. Also im going to go against whats been said before and say dont get green stuff pads. I had them on my 306GTi6 and nomatter what i did they caused massive vibration when braking hard and squeeled terribly, fitted some mintex 1144s and it cured it straight away. I dont know if these are available for the megane.
Ray
Postby Ray » Sun Jan 25, 2009 2:49 pm
a brake clean from F1 autocentres is £20.
tobyngan
Postby tobyngan » Tue Feb 03, 2009 12:12 am
thx a lot guys....finanlly get in done @ my local f1 center for £34......there is no noise now....happy to drive it again....at least for now :grin
lucydci
Currently Drives:: Megane II 1.5 dci Dymanique Sport Hatch
Postby lucydci » Tue Mar 10, 2009 7:59 pm
anth_dci wrote:make sure you have a decent amount of copper slip on the back of each pad. Also im going to go against whats been said before and say dont get green stuff pads. I had them on my 306GTi6 and nomatter what i did they caused massive vibration when braking hard and squeeled terribly, fitted some mintex 1144s and it cured it straight away. I dont know if these are available for the megane.
Agree, had green stuff on a rover 216 tom cat and it vibrated and squeeled, changed to mintex 1144 and they were fine. When we took the green stuff pads out they were all cracked, tried a few sets before the Mintex and they were all the same......crap!
2004 Black Megane II 1.5 dci Dynamique Sport Hatch
dalefletcher111
Postby dalefletcher111 » Tue Mar 10, 2009 8:53 pm
Looks like im a bit late now, but if you are in alot of rush hour traffic, you will do alot of light breaking.
This tends to shine the pads and then they will squeal when u use them, mainly when your breaking is light, like just before you stop.
Normally if u break hard a few times it will stop it. So it could be normal but Renault still sound like they're talkin b*llocks, Dirt?!
2004 1.9dci 120 dynamique 3dr
