I'm hoping my suspicions are correct and someone can confirm this for me, yesterday while parked the ABS and Service light came on (actual 'SERVICE' light, not the spanner) and as it states the ABS isn't working any more. I suspect this just means the brakes need replaced, but was wanting to confirm this with anyone. If it's something possibly more serious then i'm gonna have to scrimp the pennies together. My MOT is due in a week and it has been running perfectly fine, even with the ABS and Service light on it's still fine.
Megan Privilege 1.6 53 plate (2003)
thanks for your help
ABS and Service Light On
- Currently Drives:: Megane 1.6 Privilege
- navid.v
- Rally Driver
Re: ABS and Service Light On
I am sure I have seen posts like this before,some where because of the loose connection under the drivers seat,if I am right (worth checking).
hope this helps
hope this helps
- nickbell69
navid.v wrote:I am sure I have seen posts like this before,some where because of the loose connection under the drivers seat,if I am right (worth checking).
hope this helps
Think the one under the drivers seat is usually the airbag light. I can't seewhy they would route brake warnings under the seat( although it is Renault we're talking about)
i think the wire under the seat is something do with pre-tensioners that is linked to the airbag circuit
Each wheel has an ABS sensor. It is likely that one of them became disconnected or damaged. This has nothing to do with worn discs or pads.
