High there, finally got a day when its not raining or snowing to check out the leak on the 53 Dynamique petrol 1.6 I have.
the rear parcel shelf being wet twigged me onto the problem..... Ive taken the 3 bits of trim off around the high level brake light to see if there is anything obvious, but nothing that I could tell.
I poured some water over the top of the boot when closed and you can see a stream of water coming in right in the middle of the window..... only thing I can think of is its coming in through the high level brake light .... Anyone have a clue how to get this off so I can check its seal as I dont want to start riving at it.
Fin.
Rear Window Leak - Through High Level Brake Light?
Re: Rear Window Leak - Through High Level Brake Light?
got it cheers .... Looks like the seal around the exterior of the light is a bit bashed up ..... and typically the Renault parts department closes at midday on a Sat .... what a crock o shite.
- Currently Drives:: 04 Red Megane II Dymanique 3 Door Leather + 6 Disc changer (wifes car)
I, like you believed that the brake light was causing my leak. Upon closer inspection it turn out there was a leak between the glass and the boot frame. I phone auto glass and they wanted 150 quid to remove the glass and reseal it!!
This is where halfords helped out because i purchased 'Loctite quick gasket' On the exterior of the car I quirted a fine beed of the gasket in the gap between the boot frame work and the glass all the way across. It is extreamly sticky stuff this, so I used some washing-up liquid to act as a lubricant between my finger and the gasket. Once finished there was no leak and it looked a professional job - upon close inspection because the gasket is black it looks like a small rub seal.
Users browsing this forum: Google Adsense [Bot] and 54 guests
