Cable feed to glovebox
M3gane
Postby M3gane » Mon Dec 08, 2008 1:58 pm
Quick question - if I drill a hole in the side of my glovebox towards the centre console with a view to running my ipod cable through to the rear of my headunit is there anything I should be aware of?
Is there any area I should avoid? I want to place it relatively far back in the glovebox. And is there just one surface to drill through?
Mattj
Currently Drives:: Renault Megane 1.9 DCi
Re: Cable feed to glovebox
Postby Mattj » Mon Dec 08, 2008 4:36 pm
easiest thing is to remove the glovebox totally - its only 5 screws and is like a 2 min job, this makes it so much easier to drill and you can also see whats behind. I about 6 leads running into my glovebox (for a switch box) and I just run it thru the two holes there for the tunebox
Renault Megane II - 1.9 dCI
Gav
Postby Gav » Tue Dec 09, 2008 12:36 pm
I used an existing hole in the glovebox (Air Con I think - there was a thread asking what they were recently) for this very purpose. That was 18 months ago so I can't remember much detail...
M3gane
Postby M3gane » Tue Dec 09, 2008 1:51 pm
Oh right so I could use the aircon hole if I wanted - I take it I would definately have to drill another one if I wanted to keep that free?
Mattj
Postby Mattj » Wed Dec 10, 2008 4:20 pm
yeh i have used the air con hole - all is does is just puts cold air into the glovebox - but why do you need this ?!?
if not take the glovebox out and then cut it in the top right corner and feed the wire in - this way when you sell the car no one will see the hole
M3gane
Postby M3gane » Mon Jan 05, 2009 12:48 pm
I've used the air con hole and all is well. cheers
