scenic 1.6vvt hard to start
bingo21
Currently Drives:: megan scenic 53 1.6vvt
Postby bingo21 » Sun Sep 28, 2008 7:12 pm
Hi can anyone give me a hand.I bought a scenic 1.6vvt 53 (04) from nissan dealer in stourbridge 37,000m after 2 days had de-phaser replaced after hearing starting noise.but now 4 weeks later and the colder weather is here it's really hard to start and struggles to get 3 bars on dial drives a bit lumpy for a while,but as i go along it feels like its always struggling and lacks any power unless you rev the nuts off it.Could the guys at nissan messed up doing the de-phaser i read somewhere the computers(fuel) need to be reset....any ideas anyone :banghead
cheers in advance baza
Re: scenic 1.6vvt hard to start
Postby AlexB » Sun Sep 28, 2008 9:16 pm
Bars? Is it loosing oil in addition to drivability problems? Not good. If there are no obvious leaks, then the compression checks must be performed. I guess you are familiar with the Sales of Goods and Services Act...
bingo21
Postby bingo21 » Mon Sep 29, 2008 9:37 am
AlexB. there is no oil leak once its hot its ok,but i not 100% confident that nissan new what they were doing and now its out of warranty.... (bars on the rev counter) could it be a coil failing or dirty sensor :?:
Postby AlexB » Tue Sep 30, 2008 11:05 pm
Ah, you mean the bars on the tachometer -- it is not too bad then. Three bars mean 750rpm. The cold engine is supposed to idle faster, slowing down to 700rpm when hot and going faster again when overheated. Have you checked the temperature sensor?
bingo21
Postby bingo21 » Sun Oct 05, 2008 4:50 pm
AlexB sorry for the delay,haven't checked sensor yet,but the other day while out with lights and heater on int lights engine not running it wouldn't start flat battery dont know if this may have something to do with starting problems....!!!
terry_mccann
Postby terry_mccann » Sun Oct 05, 2008 7:28 pm
As Renault and Nissan are twin companies nowadays I think it should be ok for them to replace the pulley.
First thing to check on any Renault petrol engine indeed are the coils....they frequently are on their way out and afaik the symtoms in that case are similar to yours....
bingo21
Postby bingo21 » Mon Oct 06, 2008 9:29 am
terry, i will check the coils in the week and see if that makes it any better...thanks for your input
