Rattly Sunroof - 1.9Dci Dynamique
garlum
Postby garlum » Mon Sep 01, 2008 11:49 pm
On idling the engine creates enough vibration to cause the back edge of the sunroof to vibrate, which is a bit irritating! Has anyone had this problem, and if so is it fixable? I've had a little look at the mechanism and I haven't been able to see any obvious way of tightening it up. Any suggestions would be helpful.
Cheers,
Gareth.
andywills
Re: Rattly Sunroof - 1.9Dci Dynamique
Postby andywills » Tue Sep 02, 2008 8:30 am
sounds like the seal has gone
Postby Stranger » Tue Sep 02, 2008 12:13 pm
You could try re-greasing where it slides but, iirc, it needs to be a certain type of grease, try searching for sunroof and see what posts come up.
garlum
Postby garlum » Thu Sep 04, 2008 1:10 pm
Thanks for the above. I've checked the mechanism which looks well greased. I think the problem is just that the back eadge of the glass vibrates on tick over enough to rattle against the rubber. I'll try cleaning the rubbers to see if that helps a bit, but I think it's going to be a matter of keeping the radio on! Incidentally the noises that come from the sunroof when it's very cold are even more irritating. I suppose it's a matter of design over practicalities. I love the sunroof and I wouldn't have bought the car without it, but it is a bit annoying sometimes!
dalefletcher111
Postby dalefletcher111 » Thu Sep 04, 2008 10:05 pm
i have a rattle from the front bit that sounds like a bit of loose metal hanging somewhere, it rattles when idling. But its only when i have the cover shut on the sunroof. it goes away when i leave it open.
I was thinking it may be something to do with the spring pulling back the cover?
2004 1.9dci 120 dynamique 3dr
Users browsing this forum: Google Adsense [Bot] and 73 guests
