Door Creaking/Rattle
Clayshot
Currently Drives:: Megane Dynamique 1.6 VVT
Postby Clayshot » Wed Aug 06, 2008 11:35 pm
Please Help,I have a 2007 5door Megane Dynamique Hachback and the current problem is the doors tend to SQUEAK&RATTLE when driving on uneven roads etc. The car has been in the local Renault garage on 3 occasions for adjustments , but the problem has not been cured ANY IDEAS? . CLAYSHOT
terry_mccann
Re: Door Creaking/Rattle
Postby terry_mccann » Thu Aug 07, 2008 12:27 pm
maybe one of the door hinges has a broken pin or something? but your dealer would be expected to find sth. like this....
elsewhere, greasing everything and also using silicone spray or sth. on the door surroundings might help.....cant think of anything else.....
Tommytrindle
Postby Tommytrindle » Fri Sep 19, 2008 9:52 pm
I had a similar problem on my 3 door megane,it sounded like the lock was loose, i sprayed some wd40 into the catch mechanism, that solved the problem for a few months, then i had to respray it every 3 to 4 months
garlum
Postby garlum » Sun Sep 21, 2008 9:10 pm
Hmmm, I get this too on the driver's side of my 3 door. I might spray the lock with some PTFE grease in the morning to see if that stops it. I thought the lock was somehow slightly out of line allowing movement in the door. But if what has been said above is true then maybe I'm wrong and it just needs some lubrication.
garlum
Postby garlum » Tue Sep 23, 2008 9:48 pm
A bit of grease sprayed on the locks solved the problem for me. Thanks.
Users browsing this forum: Bing [Bot] and 56 guests
