Exhaust Gas Monitoring Warning Light Appeared on the dash today, stayed on. Whats the causes this and how easy is it to fix?
Car is a 2001 Scenic 1.6 Petrol.
ive been trawling the net looking for info and if there is some way of putting it into a test mode to read the diagnostic codes from the ECU, simple enough to do on my previous fords and scoob, but cant find a way for the renault.
cheers for any help in advance, Dan.
Re: Exhaust Gas Monitoring Warning Light
its probably a coil pack mate. if you do a search for toxic fume on here it'll chuck up loads of results. common problem
either that or the lambda
are there any other symptoms besides light on the dash, eg. sluggish, noisy, etc....
- dan-wrx
- Currently Drives:: 96 Ford Fiesta 1.4 Si, Dual Controls, Lowered, Big Sounds :o)
car is running fine, no other problems at all.
probably a sensor on the exhaust or the cat may be on its way out
Users browsing this forum: No registered users and 72 guests
