does anyone have an idea on how to turn on or connect the rear speakers in a megane 3 door. we bought the magane second hand and the things have never worked, im not sure if its a matter of turning them on or having to replace them, anyone know how i can sort it out?
cheers in advance
rear speaker problems
- nickbell69
Re: rear speaker problems
Could be something simple like the balance on the radio needs adjusting. One of the buttons when pressed says B-F this can then change the balance from front to back or both speakers. Not sure of exact button but someone will be along that'll know. Also look in ICE section better for info about speakers there.
- Currently Drives:: renault megane extreme 1.4 2003
thanks man, appreciated
- Erik Olijnsma
- Currently Drives:: Renault Mégane II GT 2.0 16V LPG Privilege Luxe
If the Fader is properly set,
get a 9v battery, get the radio out of the slot, get two wires and use the connector with all 8 wires in it. Use the both on the left and right, those are the rear speakers.
Put the wires in the negative and positive slot, and you should hear the speakers crackle when you hit the battery against the wires...if not...well, either the speakers are disconnected, not fitted or a wire broken.
But this is a fairly simple way to check, before you tear the car apart
2004 Renault Mégane GrandTour 2.0 16v (something) Luxe LPG & 1988 Renault 5 GTTurbo
Have you checked if you have any rear speakers at all in your car?
If the previous owner didn't choose the factory radio with 4 speakers, change is great that you only have the front ones, as my Megane did when I bought it second hand.
Rear speakers is not a standard option!
Users browsing this forum: No registered users and 49 guests
