mintyman5 wrote:sorry i would have replied sooner , few probs at home , my problem turned out to be dead cells in the battery , apparently this caused the ecu to be spiked causing all my problems , new battery and ecu reset seem to have sorted it out (touch wood ) its been ok since i posted the original problem
Yes and I think I would have posted 3 times as well if that had happened to me. Bet yer glad you hung onto the 2.5k you didn't have.
But it is so typical faced with a job that requires a bit of digging to find a problem they cop out and suggest buying your way out, partly I suggest because they would neithr have anyone capable of changing the loom and would not want to be faced with the problem if it didn't work after.
Sounds like you have a result.
I was going to post before I read the last one and suggest talking to the garage to see how they had come to the conclusion that the loom had "rotted", come on. Then if they had found an actual area where there was a problem, get it to an auto electrical engineer to sort out that part of the loom. but academic now.
Hope things hold out for you.
Yours, totally disgusted, Bri.
