What does this mean?
Also the car, as i said on my previous post, is not even 24 hours old! is this normal, as such?
andywills wrote:i don't bloody believe this! got my car back from garage friday afternoon, friday night the toxic fume light started flashing and the engine was noisy and struggling. looked on here, coil. limped it up to the parents as the rac cover only applies over quarter of mile away from home and they came out.
he was there in 20 minutes and i told him what it was doing, and he said before he plug the laptop in he could tell me know that is was a coil (which he had on board).
he also advice me that it would be a good idea to carry a spare coil on board just in case, and if one goes to swap them one at a time to find the knackered one.
so i thought i'd pass this advice on, keep a coil with you...dead easy to fit, one nut and they pull out.
what do you think my chances are of claiming back the £40.95 from the dealer as the car is still under warranty? the dealer is 10 miles away and I wasnt prepared to drive to there as i would have probably destroyed the 'cat' and done god knows what to the engine
andywills wrote:Gone to Renault GB direct, have absolutely no confidence that the dealer is capable
albert wrote:I took it to a main renault dealer who, having had the car for a day, said they had found no faults and had reset the computer.
andywills wrote:albert wrote:I took it to a main renault dealer who, having had the car for a day, said they had found no faults and had reset the computer.
All they will do is run a clip on it, if you're lucky, they might have paid a good 5 minutes attention to it.
Also, I would have asked them if they found no faults why would they need to reset the computer?
It could be an early warning sign for a coil. if you arent a member of AA/RAC, i would suggest you keep a spare coil and a 10mm socket in car just in case.
But if a coil does go, the dealer will point blankly refuse to reimburse you and feed you some crap along the lines of "as we did not diagnose it, it's not our problem", and you don't really want to be driving the car far with a dead coil as it can damage other parts. On the plus side thou' you'd get a 2 year warranty on the coil if the AA/RAC/etc.. fit it.
Dealers = Estate Agents = W*nkers
Users browsing this forum: No registered users and 111 guests
