Hello everyone,
I recently bought an 53 plate 2.0 priv CC with lots of toys (inc sat nav, heated seats and headlight washers), I have noticed though the rear parking sensors dont seem to be working. I am pretty technical but there is a lack of technical info on CC's so I thought I would ask the forum.
The handbook doesnt list them under any of the fuses and I did notice the other day when I removed the NS rear light cluster to change a blown bulb there were some wires scotchlocked to the main wiring on the back of the cluster which I find odd !
Can anyone point me in the right direction as to how they are connected up. Renault said they come on when the reversing lights come on, I checked and both reversing lights work so it must be something else.
Many thanks for your help.
Megane CC rear parking sensors fault
Re: Megane CC rear parking sensors fault
Sorry dont know much about the actual connection but I thought it could be the wiring for the parking sensors.
Try removing the "carpet" in the boot. I think the wires should be visible then.
I have looked in the boot as suggested, and yes there are wires !
Tucked away behind the fabric on the left hand side of the boot there is a small black box with renault stamped all over it. There are 4 wires connected to each of the 4 sensors, a red & black that goes to the buzzer (which does work as I put a battery onto it wow its loud) and another connector which has a red & black wired (schotchlocked believe it or not) directly to the reversing light wires on the rear of the light cluster) and a blue wire which does go anywhere and is taped up.
The unit gets power when the reversing lights are on and a 12v feed turns on to the buzzer but nothing happens
I suspect the unit it faulty, I am waiting for a call from Renault on the price of a new unit !
Piccy below
Piccy below
An update !
Turns our they werent a factory option then, they were fitted by the dealer after the car was delivered.
The unti has power etc but doesnt work, conclusion faulty unit. renault want £142 plus vat for a new one ! OUCH. Think I will get a £20 one on ebay and fit it myself.
Thought I would let you know as there seems to to be no mention of fuses or anything for rear parking sensors in the documentation I have anyway.
Are you going to get them put in by a garage or will you try yourself?
I will do it myself. I am very technically minded and have the practical ability.
Then in future we should talk, If I buy a RS bumper would you help me to put it on and I will give you some pocket money..... what do you say?
I would glady help but I think as I live in Cumbria and you live in Kent (?) I am a little too far away. I will gladly give you what advice I can though.
Cheers, actually do have some friends in Cumbria and might make a trip there sometime this year.
I have a 2008 renault Megane hatch back and have factory fitted beepers I have a switch on the front on the center console with the red light on saying the system is in activitie I have a cable on the back of the hand brake I am wondering would the beepers be earthed to the hand brake because since the cable came off the bacj of the hand brake I have no working beeprs
Users browsing this forum: Bing [Bot], Google [Bot] and 26 guests
