where to buy k&n airfilter megane 1.9 dci
iash101
Currently Drives:: renault megane 1.9 dci 54 plate
Postby iash101 » Sat May 31, 2008 6:18 pm
Hi does any one know where i can buy a k&n panel filter for my megane 1.9 dci 54 plate ive looked on ebay but no joy!!
cheers iash 101
Jonault
Re: where to buy k&n airfilter megane 1.9 dci
Postby Jonault » Sat May 31, 2008 6:47 pm
A lot of people use Green Cotton filters. I'm sure I've read somewhere that the oil used on a K&N filter is not very good for a diesel engine.
iash101
Postby iash101 » Sat May 31, 2008 7:03 pm
hi jonault any idea where i can get these from and are these pannel filters or will i have to remove the a air box
cheers mate iash101
Jonault
Postby Jonault » Sun Jun 01, 2008 4:26 pm
Green Cotton Filters are at:
https://www.greenfilters.com/
Easy to fit, just remove old paper filter and replace. The air box is held together with two Torx screws and is easier to get at if you remove the air inlet hose and the plastic box held in by a 12mm bolt.
iash101
Postby iash101 » Sun Jun 01, 2008 5:37 pm
[quote="Jonault"]Green Cotton Filters are at:
Easy to fit, just remove old paper filter and replace. The air box is held together with two Torx screws and is easier to get at if you remove the air inlet hose and the plastic box held in by a 12mm bolt.[/quote
Cheers jonault!! ordered geen filter from "need for speed" last night,and tuning module from diesel tuner on ebay, cant wait ,should be good !!!!!!
