kmarty wrote:100 ohm is on upper left corner (near yellow point), 270 ohm is bottom (between two switches) on the same picture. 900 ohm resistor is only "painted" (now, I have used two resistors, 820 ohm and 82 ohm, in serial because I had not more 900 ohm resistors - the one was broken as you see on picture).cncrd wrote:I did not see 270 ohm and 100 ohm in the picture.cncrd wrote:where I will connect these resistors?
And We need any extra connection?
you can see it on the picture + comments in each picture (where you need cut original connection, where attach new wiring). I think it only as example, nothing more (mainly because I don't know english well and I cannot write better guide). I am sure you will carefully check each connection with ohmmeter.In fact, CC is already in your car. You only need switch for selection between cruise control and speed limiter and control buttons for CC. Two wires from ECU ending in steering pillar, in same connector where are wires for airbag. on this two wires you need connect this. How you implement it is only your idea. I used remote control of car radio.cncrd wrote:are these connection(radio control unit) enough for cc?
Sorry for any wrong placed word, I really don't know english. Half of this was written with the dictionary. Sorry.
kmarty,
both(speed limiter and cruise control) are run well?
And I don't understant where to connect these(speed limiter and cruise control)switch?
I think we must connect 2 wires from radio control unit to there(in this picture)
