54 plate 1.5 diesel service parts
andy-g
Postby andy-g » Sat Mar 01, 2008 10:34 am
hi
im doing the service on my own car this time.
oil filter
fuel filter
pollen filter
air filter
are these easy to fit?
the pollen filter might be a tuffy, as i dont know where it is.is the fuel filter easy to fit?
can get these parts online for £42
front brake pads aswell £23
any hints or ideas mucho appreciated
thanks
andy
IainMW
Postby IainMW » Wed Mar 05, 2008 9:42 am
You can buy most if not all your parts from here
https://www.gsfcarparts.com/
Oil filter is a bit tight to get to but you should manage it.
The fuel filter is buried and you will have to take the wheel arch out to get to it :(
The pollen filter is at the back of the centre console low down, look down in the drivers foot well and you should see it (it has a tab on it to help you pull it out)
Also you heed a 5W40 ACEA B3 B4 Fully synthetic oil. Do not use 10W40 semi synthetic!
Be careful when changing pads, search the site for brake pads as there's lot's of help on that front.
xman
Re: 54 plate 1.5 diesel service parts
Postby xman » Wed Mar 05, 2008 4:22 pm
andy-g wrote:can get these parts online for £42
Just so you have a reference point, I added the prices of the parts for my 1.6 petrol here in the forum. You may want to check with your dealer and see how much it would be for original parts.
Miller999
Currently Drives:: Megane DCi 1.5
Postby Miller999 » Tue Jun 01, 2010 11:33 am
I need to change the Diesel fuel filter, can anyone tell me how to remove the wheel arch and is it the front drivers side?
