Sunroof Slides Grease?
robznet
Currently Drives:: Megane 1.5dci
Postby robznet » Sat Jan 19, 2008 11:39 am
Hi all
Does anyone know what the correct grease is for the sunroof slides? Had a quick search but didn't come up with much to do with grease.
I presume any silicone based grease would do the job, but I know someone on here will know better than me!
Regards
Rob
1.5DCi Dynamique with comfort pack - Antique Green.
cyclonebri1
Currently Drives:: Badly
Postby cyclonebri1 » Mon Jan 21, 2008 10:30 am
The demands on the grease are very low and silicone is about the cleanest you can get so I would suggest you are bang on. :cool:
robznet
Postby robznet » Mon Jan 21, 2008 4:33 pm
Cheers for that, got some knocking about in my shed, just need a dry day to do it now!!!
Regards
Rob
Postby Stranger » Mon Jan 21, 2008 7:33 pm
I'm sure that I heard mention that it needs to be a certain grease so that it doesn't affect some of the plastics / runners but I can't remember what sort. You might be better hanging on until someone can give you a definite answer, no offence to cyclonebri1 :wink:
Postby Stranger » Mon Jan 21, 2008 7:34 pm
EDIT: double post due to hanging
robznet
Postby robznet » Tue Jan 22, 2008 12:17 am
Cheers Stranger
Will hold fire for a while, don't look like I will be using the roof for a while anyway - crap english weather!
Awaiting advice!!! :wink:
Regards
Rob
cyclonebri1
Postby cyclonebri1 » Tue Jan 22, 2008 8:45 am
Silicone grease is the one. Its the safest, most inert substance available. You could actually eat it, it won't eat you or plastic.
We use it as a food safe lubricant and for all instances were resistance to interaction with other materials is a consideration. I believe it is also used for "implants" :cool: :roll: due to its safe nature.
robznet
Postby robznet » Tue Jan 22, 2008 9:33 pm
Thanks for that, will dig it out over the weekend and give the runners a good seeing to!!! :D
Regards
Rob
Users browsing this forum: No registered users and 98 guests
