Some new alloys
j4m3s
Some new alloys
Postby j4m3s » Sun Jan 20, 2008 9:20 am
Hi guys, im considering buying some alloys from a guy at work . They are 205 40 and 17". They also say they have a 34 tread. They are 4 stud so should fit. Is here anything else i should be checkin out before i get them? I have the factory fitted 16" alloys on at the moment.
Flame Red Megane 1.9 Dci
PAIN IN THE ARSE Since day 1..... :-(
Deano16v
Postby Deano16v » Sun Jan 20, 2008 12:45 pm
check they are 4x 100 and also check the centre bore on them. i think the ET on the meg is 45-49 so you might need 10mm spacers if the wheels are et34
Say..."Renno"
Postby Say..."Renno" » Sun Jan 20, 2008 1:12 pm
They're going to look lost on the car, you'd need a 50 or at least a 45 aspect tyre......34 tread ??? do you mean et 34..?if so,you definately wont need spacers.. :cool:
elgammal
Postby elgammal » Sun Jan 20, 2008 1:56 pm
205/40 will make u feel that u are driving on railroads. it will be very harsh and very stiff ride.. 225/45 would be the best fit for 17''...
Black MeGaNe II hatchback 04 _1.6 vvt manual_17" NicKeL ChrOme 225/45
potdci
Postby potdci » Sun Jan 20, 2008 3:53 pm
Your speedo will read too fast because the tyres are too small they should be 205/50/17
I bet they are off the earlier megane?
DARK MET BLUE DCI 120 + DTUK TUNING BOX & K&N Air Filter.
Jonault
Postby Jonault » Sun Jan 20, 2008 4:17 pm
I use 215/45/17 which is a very close match to the 205/55/16 original wheels and tyres. Hub centre diameter is 60.5mm.
Use a tyre calculator such as this:
https://www.alloywheels.com/tyrecalc.asp
This will help you work out the best tyre size and how far out your speedo will be.
j4m3s
Postby j4m3s » Sun Jan 20, 2008 9:36 pm
Jonault wrote:I use 215/45/17 which is a very close match to the 205/55/16 original wheels and tyres. Hub centre diameter is 60.5mm.
So best not eh? The guy said he had them on his clio.....
Not sure but im sure the tyre said 34 tread. What other numbers do i need and ill get them off the tyres.
Here are some pics.
Bohun928s
Currently Drives:: Porsche 928 S
MY08 Renault Megane dCi Sedan (wifes car)
Renault 19 hatch
'05 Suzuki GSXR 750
'00 Suzuki GSXR 750 (track bike)
Postby Bohun928s » Wed Feb 13, 2008 7:08 am
The 2007 1.9 dCi Megane with factory 16x6.5" alloys is ET49, with a centre bore of 60.1mm.
The important numbers you should be looking at will be stamped on the rim itself, once you know these you can just buy tyres at a later date the correct size.
Check the rim width and offset (ET).
For example I am replacing our alloys with 17x7 ET40 wheels, which will move them 3mm away from the inside wheel arch and push them 15mm further out towards the guards which looks like it will be ok (haven't got them yet so if anyone knows if this is a problem let me know!). With 205/50/17 tyres on they are a damn near perfect rolling radius to keep the speedo reading spot on.
Cheers,
Bohun
Bohun928s
Renault 19 hatch
'05 Suzuki GSXR 750
Re: Some new alloys
Postby Bohun928s » Wed Dec 16, 2009 7:58 am
Just for info, the wheels are now fitted and are perfect. Could even push slightly further towards the outside if you wanted, by increasing wither the width or positive offsett.
Now for the lowering springs....
Cheers,
Bohun
