rear high light
rear high light
does the rear strip light have a plug ,my light has failed and i have noticed a plug of somekind under drivers seat which is not plugged in
- nickbell69
wouldn't of thought it would be that under seat. Haynes manual says to remove light 1st remove top section of tailgate window trim panel immediately below light thenuse a small screwdriver press retaining lugs at either end of light to release it. You have to disconnect washer tube from it and wiring plug to completely remove. You could then check whether wire is getting power to it. Not sure what bulbs are in there as haynes isn't clear on that. You might be lucky and find light works with a bit of a wiggle on the wires. Someone else may come along to help that has actually removed one.
- nickbell69
- Bumpy macaroon
Users browsing this forum: Google [Bot] and 59 guests
