2004 1.9dCi Dynamique 73,000miles
I've just noticed that my seat belt warning light and beeping sound don't work anymore? I have no idea how long this hasn't been working for, I only discovered it because my brother drove my car the other day, me being a passenger.. and he usually starts driving, then puts on his seatbelt!
I've had this problem before, and it was rectified under warranty, but I don't know what they did? Just wondering if anyone else has experienced this before?
Phil
seatbelt reminder beep and warning light
- pw981
- Rally Driver
2004 Megane II 1.9dCi
- WebCode
- Rally Driver
The micro switch for the seatbelt warning light is located inside the drivers seat belt clip holster..
If you look at the holster you will see a wire coming out of it.. There is a a small slot directly beside it that if you stick a small flat instrument up the slot the cable/connector will pull out..
Sometimes the cable/connector falls out or the micro switch will be faulty..
Re: seatbelt reminder beep and warning light
I wear my seatbelt all the time on the roads. I have to take off my seatbelt to activate the barrier to get into the work carpark where there is a 15mph speed limit and I don't want to put my belt back on for this. Does anyone know if there any way of turning off the annoying beep while I park the car? Can I just put out the wire from the buckle?
- terry_mccann
I think so, yes.....some of the guys in the german meganeboard did it, I also would like to but I am a coward
but normally if you remove that cable running into the holster it should be quiet....
