brake pads
james_k
brake pads
Postby james_k » Tue Jan 01, 2008 8:48 pm
hey my megane is due a set of brake pads,
been thinking off putting greenstuff pads in instead of renaults own,
had anyone else used green stuff on them megane and what they like?
info please
pw981
Postby pw981 » Tue Jan 01, 2008 9:42 pm
No squeal, but I feel that a lot of brake 'feel' from the pedal has been lost. Its hard to describe. The initial bite when you first step on the pedal is no more...
2004 Megane II 1.9dCi
pw981
Postby pw981 » Tue Jan 01, 2008 9:45 pm
I would still recommend them though!
james_k
Postby james_k » Tue Jan 01, 2008 9:52 pm
does the car pull up better tho,
is the feel due to the brakes need bleeding?
Postby AlexB » Thu Jan 03, 2008 3:29 pm
No, I bleed brakes every year...
I would describe the feel of GreenStuff as smooth-progressive-secure. There is less of on/off feeling and no fading. It is always good to have more control in the process of braking.
It makes little difference for normal driving in the UK, but somewhere in mountains on a serpentine road one would appreciate this characteristic. Imagine, overtaking downhill, braking sharply just before the bend, braking gently in the bend to prevent understeer, then accelerating again to the next bend...
james_k
Postby james_k » Thu Jan 03, 2008 7:43 pm
so you would used them again next time?
06/55plate Renault Megane 1.9DCI (130) Dynamique 3 door!
Postby AlexB » Fri Jan 04, 2008 12:47 am
Yes, I will. Furthermore, our former rally driver LGC (Antmat at Parker's) recommended these pads in his early messages, which unfortunately disappeared due to the database crash.
He also warned me against changing the rear pads only, which may upset the balance under braking. So, I've installed GreenStuff all around.
Ray
Postby Ray » Fri Jan 04, 2008 6:47 pm
I have these pads. They're good. There's not much choice though for aftermarket pads. Hopefully i'll have a better feel with them after my 36k service and brake fluid change tomorrow.
Deano16v
Postby Deano16v » Fri Jan 04, 2008 7:20 pm
in my experience the greenstuff pads are more progressive. like has been siad before you do lose some of the initial bite, especially when the brakes are cold but you do gain in more feel through the rest of the pedals travel.and they give off less dust
james_k
Postby james_k » Fri Jan 04, 2008 7:51 pm
thanks for all the help guys,
i will get some ordered, i think im going to get them from ebc direct, think there the cheapest,
