Dodgy Bit...
kylehimself
Dodgy Bit...
Postby kylehimself » Wed Jan 02, 2008 3:10 pm
well chaps this could be nout. but anything out of the ordinary on megane scares me, so here it is.
the black plastic mold at the bottom of the windscreen. one section about 4-5 inches of it has lifted up about a 1/4 inch or so off the window. when i lifted abit more to look in. it LOOKS like there a white clip but when i push on it it doesnt seem to catch anything. would i have to pull it out and have a look to try and fix it. or could i just (and this may sound stupid) like use silicon to stick the bit thats sittin' of the windscreen down??
i dont like it sittin' up cause water could get in, now the water might just drain straight out, but again... its a meg so better safe than sorry.
i will try and get a pic up after work incase what im sayin' doesn't make alot of sense.
Ray
Postby Ray » Wed Jan 02, 2008 6:38 pm
pics definitely needed.
72uoba
Currently Drives:: Renault Laguna 2007 GT 175
Postby 72uoba » Thu Jan 03, 2008 8:27 pm
very much so :lol:
Say..."Renno"
Postby Say..."Renno" » Thu Jan 03, 2008 8:41 pm
Is it the triangular piece that sits in the lower corners..or the one that goes along the bottom of the screen itself....if its this one chances are you'll have to take more of it off to replace the clip that's left behind..and probably the other clips along the way...murphy's law.. :wink:
kylehimself
Postby kylehimself » Fri Jan 04, 2008 10:48 am
heres the pics for above. again, this could be nothin' but it just annoys me now that ive noticed it lol. see what you make of it...
kyle :cool:
Say..."Renno"
Postby Say..."Renno" » Fri Jan 04, 2008 1:35 pm
Chripes Kyle did you move to Hawaii.. :D
Get yer big mutton fingers out of the way....... :lol:
kylehimself
Postby kylehimself » Fri Jan 04, 2008 5:40 pm
:lol: i was actually lookin' at that pic with the reflection in the window and thought "frig belfasts lookin' alright here" that was taken' y'day just before the snow to.
m.bedforth
Currently Drives:: Megane Sport Tourer Oasis Dynamique Manual Petrol '05
Postby m.bedforth » Fri Jan 04, 2008 5:51 pm
It's exactly the same on my 1.6 vvt 05 Sport Tourer. I noticed it the other day when I was removing leaves and other debris from that area. Does it affect anything?
pw981
Postby pw981 » Fri Jan 04, 2008 6:20 pm
mine is the same too, a 2004 1.9dCi dynamique. Not sure about the white things inside though I haven't tried pulling it up.
2004 Megane II 1.9dCi
Say..."Renno"
Postby Say..."Renno" » Sun Jan 06, 2008 2:44 pm
O.K FOLKS..Took my trim off to see if i could help here...
Three pix to look at..the white clips on the trim actually hold it in place but they hook under the w/screen, so i dont think they'll just push back..anyway its a five min. job...
You'll need a long nose pliers and a flat medium screwdriver..
First remove the 2 black plastic screw fixings at the end of the trim..obvious..btw they are the hardest part of this i found..to those that dont know ,you only need a quarter turn, then get your nails/fingers under the screw part. .the whole thing comes out
Next..remove the side trim..theres a green fixing pin just inside the bonnet hinge pic 1....you need to squeeze this with the pliers..it pops quite easily...next gently prise off the trim with the screwdriver (you may be more comfortable putting some tape around it) , its held with 2 pop off's ,white in the pic.1...
Next..lift out and frontwise the trim(pic.2) slightly to expose the trim clips (white).....pic.3
Easy...Depending how long your trim has been misplaced ,it may have taken up that shape and still stand proud when replaced..i would say leave it as the heat from the sun (hopefully) may help it back to shape..or if youre brave stick a hot air gun on it for a few seconds.....
As usual refit is a reversal of the removal.. :cool:
https://i250.photobucket.com/albums/gg24 ... C00167.jpg
https://i250.photobucket.com/albums/gg24 ... C00168.jpg
https://i250.photobucket.com/albums/gg24 ... C00169.jpg
kylehimself
Postby kylehimself » Sun Jan 06, 2008 6:51 pm
cheers pat!
will have to wait for the weekend to give it a go since its always dark by the time im home from work. nice instructions tho.
thanks again!
kyle :cool:
kylehimself
Postby kylehimself » Sun Jan 20, 2008 2:03 pm
just got round to doin' this y'day. worked a treat... cheers for the help mate
kyle :cool:
Say..."Renno"
Postby Say..."Renno" » Sun Jan 20, 2008 5:24 pm
Its why we're here.............. :cool:
Had mine off again to do the springs...easy when you've done it before.. :wink:
Users browsing this forum: No registered users and 66 guests
