air con advise?
toptonyb
air con advise?
Postby toptonyb » Tue Jan 01, 2008 10:40 pm
hi, hope you all had a great christmas? wishing you all the best for 2008,
just a stupid little question i need answering if poss?
if an air con system is low or empty will it not engage the relay & compressor? my light lights on the button on dash but no cooler air/click from relay/compressor & no drop in revs happens? nationwide autocentres advised me the air con is running low? or empty?(has a leak?)
anyone confirm this?
cheers pals.
04' 1.5tdci, black, superb mpg, £35.00 tax, dirt cheap insurance, superb looking.
Ray
Postby Ray » Wed Jan 02, 2008 1:01 am
I doubt modern cars (esp diesel ones) will have a drop in revs as the aircon kicks in.
pw981
Postby pw981 » Wed Jan 02, 2008 4:35 am
If the gas is low, yes the compressor will not engage.
2004 Megane II 1.9dCi
BurntCarcus
Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Postby BurntCarcus » Wed Jan 02, 2008 4:34 pm
If you have never had it looked at or regassed i would advice calling into kwikfit or the likes and get it checked out, my '04 was almost out of oil when i took it in, was told it could have been a nasty repair bill had i not got it refilled.
markren2004
Postby markren2004 » Thu Jan 03, 2008 11:02 am
BurntCarcus wrote:If you have never had it looked at or regassed i would advice calling into kwikfit or the likes and get it checked out, my '04 was almost out of oil when i took it in, was told it could have been a nasty repair bill had i not got it refilled.
excuse my confusion, but what has low oil level got to do with the Air Con ?
The Negotiator
Postby The Negotiator » Thu Jan 03, 2008 11:20 am
He meant the oil in the air con system, not engine oil.
dci120matt
Currently Drives:: 2001 Peugeot 306 GTI-6 ohh yesss
1988 renault 5 1.7 GTX
Postby dci120matt » Thu Jan 03, 2008 12:11 pm
my air-con has stopped working so i took it to a garage they re-gassed it but the compressor still does not kick in, so i assume its knackered, as the garage didnt say much.
cactusbob
Postby cactusbob » Thu Jan 03, 2008 12:27 pm
It could be the air-con gas pressure sensor at fault, quite a common problem
225 5dr FF + Xenons
http://www.meganesport.net
BurntCarcus
Postby BurntCarcus » Thu Jan 03, 2008 12:47 pm
as Negotiator says, there is oil in the aircon that needs topped up too. Costly if it runs out and drys up.
toptonyb
Postby toptonyb » Fri Jan 04, 2008 7:38 pm
i got it booked in at kwik fit tomoro morning (sat 5/1)for them to re-gas?? i'll let you all know?
a couple of people have mentioned the sensor or the relay? are these easy to change/check?
toptonyb
Postby toptonyb » Sat Jan 05, 2008 10:01 pm
my megane has been to kwik fit for an air con recharge & leak test? everything went fine,it took in oil & gas & holds it with no leaks (yipee)
but the compressor still does not 'kick in'?? so there was no charge for this as kwik fit was not able to improve by 10% (good service from k/f)
the mechanic advised checking all fuses/wiring/relays & sensors before taking it to dealers? i have no idea where the sensors/relays are on my car ( i've found the fuses, they are ok)
i have just bought a hayes manual to try & help me with this issue but it will not arrive till mid week, in the meantime is there any advice from any one out there? many thanks :-)
The Negotiator
Postby The Negotiator » Sat Jan 05, 2008 11:18 pm
cactusbob
Postby cactusbob » Sun Jan 06, 2008 12:23 am
I've yet to find a Renault Minute anywhere near me. :D
225 5dr FF + Xenons
dci120matt
Postby dci120matt » Sun Jan 06, 2008 10:46 am
just go on to the renault uk website and you can do a search to find your nearest renault minute garage.
toptonyb
Postby toptonyb » Mon Jan 07, 2008 9:51 pm
hey thanks for that Negotiator,
just out of curiosity does anyone know where the pressure sensor is located on the megane? i've had several people mention this could be at fault? cheers
