Megane II 1.6 manual response and acceleration
snowy
Postby snowy » Sun Dec 30, 2007 11:29 pm
my second gear is fine. i dont really care if its not as powerful as a dci, cause its very comfortable, smooth, quiet and reliable, (touch wood!).
i think i will stick with it so long as it gives me no problems. im gonna fit my iridium sparks this week.mines the same colour as yours mr asia, and ive got the panoramic sunroof too! :cool:
elgammal
Postby elgammal » Mon Dec 31, 2007 6:52 am
the point is that it was also lacking power in 2nd gear before 17" rims when i had the 15". anyhow, it is not a big issue for the car as whole... :banghead
so, mrAisa, do u recommend that i buy the irridium spark plugs or not :roll: ??
snowy, please inform us of the irridium spark plugs as soon as u fit it in?
Black MeGaNe II hatchback 04 _1.6 vvt manual_17" NicKeL ChrOme 225/45
MrAsia
Postby MrAsia » Tue Jan 01, 2008 2:36 am
I've got the iridium sparks and I won't go back to standard, they work out to be cheaper then standard plugs in the long run as they last longer and also my idle is sooo much smoother.
Definitely notice the difference in my manual car.
Remapped Mégane 1.6L
BurntCarcus
Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Postby BurntCarcus » Tue Jan 01, 2008 10:32 am
If you get bigger rims you should be putting smaller walled tyres so they should still be nearly the same size. I have 18's on and they are 1 mm smaller than my 16's because the side wall is only 40 not 65 like the old ones. There is a handy site that calculates it all for you and shows you how much your speedo will be out, ill try and find the link.
LINK HERE
MrAsia
Postby MrAsia » Wed Jan 02, 2008 3:59 am
It's not about the size, the bigger you go the heavier the rims will be, thus reducing acceleration.
elgammal
Postby elgammal » Wed Jan 02, 2008 7:01 am
u know, the problem of feeling the lack of power in low revs in Megane is the technology of its engine..
i mean that any car has coils/wires attached to the spark plugs from one side and to the engine from the other side.. however, in our car the spark plugs are attached directly to the engine (with neither coils nor wires)..
theoretically, this tech. should decrease petrol consumption and increase efficiency (power and response) i suppose
Bumpy macaroon
Postby Bumpy macaroon » Wed Jan 02, 2008 7:52 pm
meganes have coil packs attached to each sparky, so we have four coils each fed LT to produce the HT at the correct time by the CPU, in days of old you had one coil feeding the distributor cap which fed the volts to the correct spark plug according to the rotor position. this distributor and single coil was evantually replaced by electronic timing pack still fed out four invidual HT lines now replaced with the four coil packs per individual sparky, in theory this should be more reliable less power buzzing around and less distance for it to travel before producing the spark, but that assumes that the coil packs renault used were good stock.
Bumpy and full of coconuts.
cactusbob
Postby cactusbob » Wed Jan 02, 2008 8:33 pm
Bumpy macaroon wrote:but that assumes that the coil packs renault used were good stock.
Which generally they werent
225 5dr FF + Xenons
http://www.meganesport.net
elgammal
Postby elgammal » Thu Jan 03, 2008 7:27 am
i agree too that the coil packs aren't that efficient! but can't they be changed to more kind of sporty ones??
Bumpy macaroon
Postby Bumpy macaroon » Mon Jan 07, 2008 9:06 am
well you could paint some go faster stripes on them LOL
elgammal
Postby elgammal » Tue Jan 08, 2008 8:35 am
:lol: :lol:
elgammal
Postby elgammal » Tue Jan 08, 2008 12:12 pm
guys, anyone installed a chip for a 1.6 vvt 04 meg?? what does it do? :-P
i think it gives like 20-25 bhp
potdci
Postby potdci » Tue Jan 08, 2008 6:46 pm
A good chip usually gives about 5-10% increase on a normally aspirated petrol engine, my mates old 172 clio went from 171bhp up to 184 on the rollers but he couldent really notice it when driving, it could iron out any flatspots though.
DARK MET BLUE DCI 120 + DTUK TUNING BOX & K&N Air Filter.
elgammal
Postby elgammal » Thu Jan 10, 2008 8:00 am
do u know how it is installed and/or how does it look like? :oops:
potdci
Postby potdci » Thu Jan 10, 2008 9:59 pm
You wont see anything it is all ECU related :)
The 1st one i had chipped by was my swift gti with a BBR starchip 12 years ago... the ECU was removed the original chip de-soldered and the new one soldered in hard work! gained 6bhp but raised my rev limiter from 7800rpm to 9000rpm... but now it is all done by computer nice and easy!
