Noise from behind dashboard
speedy_glz
Postby speedy_glz » Thu Nov 08, 2007 3:35 pm
Hi everyone,
since like 1 month ago my Meg has a very anoing noise that comes from behind dashboard, like something was vibrating, and most od ths times it stops after a while driving.
Has any one this problem?? :shock:
Need help
Thanks a lot!!
IainMW
Postby IainMW » Thu Nov 08, 2007 3:52 pm
Where in the dashboard is this noise coming from?
Jonault
Postby Jonault » Thu Nov 08, 2007 5:17 pm
I had a rattle from inside the dashboard but it turned out to be something in the glovebox. I only found this out when I asked the passenger where they thought the noise was from. I get occasional clicks from the top centre part of the dashboard where the clock/tuner/CD screen is.
speedy_glz
just
Postby speedy_glz » Thu Nov 08, 2007 5:39 pm
the noise (like a rattle) its just from the top centre part of the dashboard where the clock/tuner/CD screen is, as you describe.
2005 Megane II Dynamique, hatch Capsicum Red, 2.0 Lts engine, solar sunroof, 17" alloy wheels, 6 gear trans
Jonault
Postby Jonault » Fri Nov 09, 2007 11:33 am
I think this is a common fault, I'm sure I've seen a fix somewhere on this forum involving removing the top centre piece and either trimming off parts of the locating tabs or greasing them so that they don't click when they move. Mine doesn't rattle enough to warrant taking any remedial action at this time.
speedy_glz
Postby speedy_glz » Fri Nov 09, 2007 9:47 pm
if anyone here knows the solutions or had the same problem, I really appreiate your help. That noise its a really pian in the a.....
What I noticed is that the noise started just after I tooke the car to the dealer for the 45000 km service.
Jonault
Postby Jonault » Sat Nov 10, 2007 9:12 pm
This thread tells you how to remove the top section:
http://www.meganeownersclub.co.uk/forum/viewtopic.php?t=5160&highlight=dashboard+rattle
I expect it'll just be a case of greasing the bits that rub together.
speedy_glz
Postby speedy_glz » Sun Nov 11, 2007 1:33 am
thanks so much jonault!!!
hope it will work! :cool:
IainMW
Postby IainMW » Sun Nov 11, 2007 7:30 am
Try padding out all the contact area's of top section where it meets the dashboard with thin strips of foam rubber.
Window draft excluder foam strip is very good for this. Failing that a squirt of silicone trim lubricant work just as well :cool:
Users browsing this forum: No registered users and 63 guests
