Diagnostics test cost
dolbz
Postby dolbz » Fri Oct 12, 2007 8:27 am
I've been having a toxic fume light problem as I said in the sticky thread.
We took the car into our local dealer and they want £57 just to run a diagnostics test. Is this normal? and how can they justify prices like that just to plug a computer into it and take some readings? Also will they charge this on top of any work that needs doing? If so this is going to be very expensive....
Nathan
IainMW
Postby IainMW » Fri Oct 12, 2007 8:39 am
If the car is out of warranty most dealers will charge you for plugging it in to the computer.
It sounds like you have one or more faulty coil packs if you are getting this message.
Very common problem on Meganes, but easily fixed by replacing the duff coil(s)!
dolbz
Postby dolbz » Fri Oct 12, 2007 8:48 am
Thanks for that. Yeah I read about the coil problem but the car still runs fine (no misfires, chugging etc) and I read about a possible cam shaft sensor problem which can also cause this light. If I knew for certain it was the coils I'd pick some up and do it myself but it'd be useful to know the results of the diagnostics to be sure...
petesafc
Postby petesafc » Sun Oct 14, 2007 10:10 am
Join the AA online £69 they will come out and do diagnostic checks as part of your cover and give good advice.
dolbz
Postby dolbz » Mon Oct 15, 2007 1:22 pm
Glad I got the test now. It didn't turn up anything but the guy noticed the clattering noise on startup and said it sounds like a dephaser problem. He recommends not driving it else it'll just make matters worse. Is this true? I've only had the bloody thing for just over a week and got this already :(
Regarding the toxic fumes light it just turned out that a sensor connection was loose. They wiggled the wires and the light went off. I love technology :cool:
Next step try and speak to the guy who sold it me who gives a warranty for 'major mechanical parts'...what do people think...will this be covered under that? When I spoke to him initially he said it's for major engine issues and transmission etc
IainMW
Postby IainMW » Mon Oct 15, 2007 2:52 pm
The Dephaser Pulley is a major engine issue!
Kiss goodbye to £500 to get it changed out of warranty. If you've only had it a week reject the car!
dolbz
Postby dolbz » Mon Oct 15, 2007 3:57 pm
If he agrees to pay for the repair (which he should according to what has just been said) is this something that only a renault dealer should do? As from what has been said on these forums it's a very big job which will take 8 hours and I'd feel a lot more satisfied getting the pro's to do the right job.
IainMW
Postby IainMW » Mon Oct 15, 2007 4:47 pm
I would make sure it is done by a Renault Dealer, the one where you had the diagnostic test done seeing as they discovered the fault.
MeganeChick
Currently Drives:: Black Gold '06 RenaultSport Megane 225: lux, cup pack, full tints, custom exhaust, blanking plate, custom air intake feed, RSTuning remap (255bhp), ITG panel filter, Samco silicon air intake pipe, Forge Intercooler, renaultsport alloy wheel decals, xenons, xenon white interior and exterior lighting upgrade, FLI trap 12 active subwoofer (1000 watts) :D
Postby MeganeChick » Fri Oct 26, 2007 8:32 am
my local non-renault garage quoted me £20 for diagnostics - might be worth asking about?
'06 RenaultSport Megane 225: lux, cup pack, full tints, custom exhaust, xenons, xenon white interior and exterior lighting upgrade, tuned, FLI trap 12 active subwoofer (1000 watts) :D
Users browsing this forum: Bing [Bot] and 63 guests
