Steering Not Locked?
robznet
Currently Drives:: Megane 1.5dci
Postby robznet » Fri Aug 03, 2007 12:15 am
Hi all
Driving home this evening, doing a steady 40 mph on one of our local (with many traffic cameras) A roads. My service light came on along with the message "steering not locked" on the display.
I remember thinking in a split second "god - I hope it don't lock now!!!).
The message and the service light went out after about 20 seconds and didn't come on again. Car was serviced 3 weeks ago and this is the first time I have seen this, (hope it will be the last!)
Anyone seen this before? If not - should I book it in for diagnosis at the dealer?
Don't know if I should be worried or not - any feedback on this would be greatly appreciated.
Regards to all
Rob
1.5DCi Dynamique with comfort pack - Antique Green.
markren2004
Postby markren2004 » Fri Aug 03, 2007 11:25 am
you get this message if you switch off the car, don't remove the keycard, and wait for 20mins (or might be a hour ?).
It seems the message is related to when all the electrics switch themselves off to save the battery.
normally the electronic steering would lock, but as youve got the keycard still in the slot, it says "Steering not locked" at that time.
can't shed any light why you'd get this whilst driving. hope it's just a blip.
robznet
Postby robznet » Fri Aug 03, 2007 12:30 pm
Cheers for the reply
I hope it's just a blip too - will see if it happens again!
Regards
Rob
Rib Roch
Postby Rib Roch » Fri Aug 03, 2007 4:20 pm
I had the same message every time I turned the engine off, but at the same time had the notorious air bag indicator light problem. Once I'd checked my connectors under the seat for the airbag links, everything worked fine including the steering lock.
52 Megane 1.6VVT Dynamic RED
04 Scenic 1.9dci Dynamic BLACK
candy_xyz
under passenger seat
Postby candy_xyz » Tue Aug 14, 2007 12:39 pm
i agree with what rob said, a wire under your seat may be lose, sort that out and everything should be fine, I had the same problem with mine
xx
Megane VVT Dynamique (2 door) Hatch
Petrol, Manual
1.6 Engine
'53 plate registered October '03
Mileage 47k (March 06)
arran.vigar
Currently Drives:: Megane II 03
Re: Steering Not Locked?
Postby arran.vigar » Sat Apr 23, 2011 9:30 pm
Do you know which wires should be checked as same issue us with mine =[
Users browsing this forum: Google [Bot] and 43 guests
