When general driving and turning the steering wheel there is a constant ticking or clicking sound as if something is stuck behind the steering wheel, I had a look and it looks as if the airbag has come loose
Cheers.
robznet wrote:Hi
Will be the rotary switch behind the steering wheel. Had mine replaced under warranty but if you do a search for the posts on here about the switch, you will find that they generally do not last long without starting to make the noise again.
Mine is still clicking but not as bad as before I had it replaced. Book it in and get it changed anyway - it is a common problem.
Regards
Rob
Users browsing this forum: Google [Bot] and 48 guests
